Results 1 to 3 of 3
Thread: Garmin Quest Handlebar Mount - £2.50 !!!!
    steved1969's Avatar
    steved1969 is offline Member
    May 2008
    Pontefract, W Yorks
    Just over a year ago I decided to splash out on a Garmin Quest sat nav system, I chose the Quest as it was quite small and rugged, and they did a motorcycle mounting kit for it along with the car one (it's also waterproof).
    Unfortunately (like many no doubt) I was rather disappointed to discover that the motorcycle mounting kit didn't really offer any ideal way to mount the setup on the motorbike. Searched for ages trying to find one, before discovering the perfect solution, a pair of radiator pipe holders from Focus DIY! Designed to hold pipes to the wall I was thrilled to discover that they would also clamp onto the handlebars of the TransAlp, and whats more the four screw holes intended to fix the brackets to the wall were ideally spaced to hold the Garmin Quest motorcycle mount, result!
    Namby Pamby scaredy cats could put some tape on their bars before clamping the pipe holders to them if they really wanted to.
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    Re: Garmin Quest Handlebar Mount - £2.50 !!!!
    good thinking, they could be used to hold loads of things
    Dee Duble Yuh's Avatar
    South Wales, UK
    Well that was flippin' obvious. So obvious, that... err... no-one else had thought of it before... err... well done mate!
    DW (Dave)
    "Let's ride motorcycles!"
  1. Garmin Quest/Quest 2
    By Whealie in forum Accessories
    Last Post: 23-10-07, 06:25 PM
  2. Garmin Quest
    By fw750x in forum Chatter
    Last Post: 29-09-06, 10:17 PM
  3. Garmin Quest
    By sa6andy in forum Chatter
    Last Post: 04-07-06, 02:52 PM
  4. Garmin Quest
    By xrv_jim in forum Chatter
    Last Post: 12-12-04, 04:48 PM
  5. Garmin Quest
    By sa6andy in forum Africa Twin
    Last Post: 01-01-70, 02:03 PM
