Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
Thread: Super Easy Power Socket......
  1. #21
    pete h's Avatar
    pete h is offline Plodder
    Jan 2008
    Yorks/Lancs border country
    Re: Super Easy Power Socket......
    I bought mine at hein gericke, about 7.99 i think. might be cheaper at an rs store or maplins.
    Not sure about waterproof but it's got a cover, and I mounted mine under the seat on the vara so you access it from the nearside through the gap in the panels. wired straight to the battery with an inline fuse, and never had any water ingress issues in a years use. i use it for the optimate every night, and charging everything from mobiles to cameras when i'm out and about.
    pics etc are here:
    power socket fit
    Redbus's Avatar
    Redbus is offline Member
    S.W. London
    Question Re: Super Easy Power Socket......
    Quote Originally Posted by btbloke View Post
    I'm not sure I'd plug anything in in the rain. I have used the din plugs
    http://cgi.ebay.co.uk/BMW-style-Powe...1%7C240%3A1318
    http://cgi.ebay.co.uk/BMW-Powerjet-1...1%7C240%3A1318
    (very common on bt equipment from the old days and still used by BMW now i do believe) but try finding a phone/ipod/sat nav or anything with a din plug end. you have to have an adaptor plug or change the end of every item to din and then your chargers won't work in the car or other peoples bikes.
    I don't advise anyone to plug anything in in the rain or when riding along,you risk not only blowing the fuse in the plug in item but also the item your charging will get muller'd.
    Anything that needs to be charged whilst on the move shold be wired in to the battery or loom with the appropriate relays and fuses etc.
    The socket I have is only waterproof for the sake of having it out in the open where it easily accesible without having to remove the seat (especially when your loaded up with camping gear etc) to get to it. It has taken the worst of the weather and never given any trouble, just flip the lid out and off you go,instant juice for the ipod and phone.I'e even used one of these if I'm in a rush to charge phone and Ipod.
    http://cgi.ebay.co.uk/Twin-12-volt-c...1%7C240%3A1318
    Totally agree with you BT. mines the same as yours but a din socket. but i'm looking for someway to waterproof the the plug and socket in use with gps etc. and i thought a bodger might have an idea how or what.
    Wish i could post piccys but i'm stupid,
    Les
  4. #23
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    What GPS are you needing to charge?
  5. #24
    Redbus's Avatar
    S.W. London
    Zumo550 but power, not charge
  6. #25
    btbloke's Avatar
    Northampton
  7. #26
    Redbus's Avatar
    S.W. London
    Each to his own. Seems like your using the basic setup cable that came with the gps but added a relay. Its just that I've dedicated my little mind to making up a waterproof in use plug and socket arrangement. I did the same with a 2610. cut cable to reasonable length put on combi din/ciggy plug with built in fuseholder and correct fuse for 2610. worked a treat. with more than 1 bike I just swap unit to choice.
    just as I cant post piccys I hate playing with plastic body panel in case I break a lug.
    see you around BT. thanks. now wheres that imaginary shroud i want.
  8. #27
    criboun is offline Junior Member
    Nov 2008
    London
    I'd like to install a 12v waterproof power sockets on my transalp to occasionally charge my mp3 and mobile phone.
    I'm a little unclear on the fuse situation though...
    Am I correct in thinking that I need to put an inline fuse holder on the positive/negative cable if it doesn't have one inbuilt?
    Please can someone tell me what Amp fuse I should use for the electrical items mentioned above.
    Thanks,
    Ollie
    Greasy Sprocket
  9. #28
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    Quote Originally Posted by criboun View Post
    This guy sells keenly priced and in my experience well presented and put together leads etc. They include instructions etc as well
    Towsa
    steveR
    Project Red KMX200
  10. #29
    btbloke's Avatar
    Northampton
    i use 30 amp cable, a ten amp inline waterproof fuse and never had a problem
  11. #30
    Nov 2008
    London
    Thanks for the info. Much appreciated.
    Ollie
    Greasy Sprocket
  1. power socket fit
    By pete h in forum Varadero
    Last Post: 13-03-08, 12:16 PM
  2. Pee'd off with Power Socket
    By rufusrusty in forum Transalp
    Last Post: 04-02-08, 12:59 PM
  3. Well that was easy!
    Last Post: 04-07-07, 10:21 PM
  4. Power socket
    By DaveS in forum XR
    Last Post: 02-07-07, 09:41 PM
  5. Power Socket
    By Mr NiceGuy in forum Mechanical Advice
    Last Post: 16-02-07, 09:31 AM
