Results 1 to 3 of 3
Thread: Brake Bleeding
    1gear1brake's Avatar
    Portland, Dorset
    Brake Bleeding
    This is a method I have pinched from Shimano's instructions on how to bleed their hydraulic mountain bike disc brakes. Shimano says to attatch a hose to the bleed nipple, and then tightly cable tie a bag to the end of the hose and suspend the bag from somewhere above the caliper. So now, when you undo the bleed nipple and pump fresh brake fluid through, any bubbles rise up the tube and into the bag. If anything is sucked back into the caliper, it will only be brake fluid (no air).
    As I work in the store of a hospital, I managed to aquire this handy bag/tube aparatus which does the job perfectly. It even has a tap in the bag to drain the fluid out .
    Dylan
    BIG D's Avatar
    BIG D is offline Senior Member
    MORAY
    Re: Brake Bleeding
    That is a very good idea, and a far better use of those bags or cathators than originaly intended, last time I saw one it was stuck some where I will not mention .
    BIG D
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Re: Brake Bleeding
    aha yes
    merv
  1. Brake Bleeding
    By russellt in forum Mechanical Advice
    Last Post: 21-11-09, 02:09 PM
  2. Bleeding Brakes
    By Simon WS in forum Dominator / FMX
    Last Post: 06-03-08, 05:53 PM
  3. Brake bleeding.
    By old red eyes in forum Other Bikes
    Last Post: 18-03-07, 04:54 PM
  4. bleeding brakes
    By wab in forum Transalp
    Last Post: 30-11-06, 01:27 PM
  5. I have a bleeding problem
    By Maverick in forum Chatter
    Last Post: 14-02-06, 06:15 PM
