Results 1 to 10 of 20
Thread: DIY scottoiler
    Gotham's Avatar
    Gotham is offline adventurer
    Tallinn
    DIY scottoiler
    Hello!
    Did a some kind of oiler a month ago and thought I'll share it.
    The idea is to use solenoid valve to start and stop oiling.
    Found a suitable one from eBay My World - valves4projects
    NB! It's 12V gravity feed solenoid valve.
    Cost $15.49 + $7.95 (item+shipping)
    Other parts altogether cost less than 5€.
    Some of them:
    Used silicon clue (not the on that is based on vinegar, used some kind of Wurth polymer mass) for connecting parts and got this one:
    From reservoir there are two hoses: one for oil flow and the other one for breathing. It would have been better if the last one would have been on the other side but this way it was easier for me.
    The dual injection is made from WD40 spraying stick that is cut to half.
    On the top there are hose clamp for mounting it to gear change shaft. The wire that should help to position the dropping points was not so good idea in this way. Later used less wire for positioning and some cable ties to do this.
    Now the installation. As I use gravity for flow the reservoir must put to highest place (under rear mudguard) and next parts go lower and lower.
    The valve gets the signal from fuel pump so when the engine starts the valve opens and starts to oil and when it stops the oiling ends. I use one clamp that squeezes the bottom hose for regulating the flow.
    All this works fine. I've been quite lazy to regulate the right flow (1-2 drops per minute) so there are quite much oil at the moment. And I think that I should replace the reservoir bottle (Rexona shower gel) for better one cause I think when it get hit with a rock it will be smashed.
    Cheers,
    Gotham from Bodgers Corner
    fatowl's Avatar
    May 2006
    Near Exeter, Devon
    Re: DIY scottoiler
    Like it! A damn sight cheaper than a real ScottOiler!
    BTW Any idea what the curent draw on the valve is?
    Apr 2007
    East Anglia-ish
    Re: DIY scottoiler
    Thats not a bodge, thats an engineering solution....Well done
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    Gotham's Avatar
    Tallinn
    Re: DIY scottoiler
    Quote Originally Posted by fatowl View Post
    Technical Specifications for the valve:
    Model EHCOTECH DDT-CD-12VDC
    Voltage 12-Volt DC
    Current 600 mA
    Operation Mode Normally Closed (valve opens when energized)
    Valve Type Direct Acting, Wet Armature
    Inlet/Outlet Ports 1/2 Inch Straight Pipe Threads (14 threads per inch / outside diameter 27/32").
    Pressure Rating 0-24" Water Column (do NOT use with pump pressure)
    Flow Rate 0.8 GPM (with gravity)
    Suitable Media Water, Very Low Viscosity Fluids
    Temperature Limitations Maximum Fluid Temperature 140° F
    Filter Screen Removable Stainless Steel Inlet Filter
    Materials
    Valve Body / Guide Tube Nylon
    Spring Stainless Steel
    Plunger Stainless Steel
    Plunger Tip Silicone Rubber
    Mounting Can be attached with two 3 mm machine screws (not included)
    Mounting Position
    Coil upright preferred
    Estimated Valve Life More than 250,000 Cycles
    Quote Originally Posted by meljordan View Post
    Thats not a bodge....
    Sorry about that
    severs's Avatar
    severs is offline TV boffin
    Re: DIY scottoiler
    How do you refill the reservoir?
    Gotham's Avatar
    Tallinn
    Re: DIY scottoiler
    Quote Originally Posted by severs View Post
    I remove the cable ties and then I'm able to put the bottle upright so I can remove and install the bottle without dripping oil to a ground. And I put new ties when reinstalling it. I found this was the cheapest and easiest way to install the bottle on that time. Of course there are many other ways to do it.
    XRV freak is offline Member
    Sep 2008
    Slovenia
    Re: DIY scottoiler
    How are you adjusting oil flow?
    Gotham's Avatar
    Tallinn
    Re: DIY scottoiler
    Quote Originally Posted by XRV freak View Post
    As I said
    Quote Originally Posted by Gotham View Post
    ... I use one clamp that squeezes the bottom hose for regulating the flow...
    Kjell Lindberg's Avatar
    Sweden
    Re: DIY scottoiler
    Do you have any facility for a breather in the system?
    Since you slowly emptying the bottle, air needs to fill the volume you let out, otherwise the flow will stop due to under pressure, or will it work with air being drawn back through the small hose?
    AlanH's Avatar
    Bristol, UK
    Re: DIY scottoiler
    Quote Originally Posted by Kjell Lindberg View Post
    In the original post...
    Neat solution
  1. Scottoiler
    By Nareef in forum Mechanical Advice
    Last Post: 21-12-08, 10:51 AM
  2. scottoiler
    By bazza in forum Africa Twin
    Last Post: 20-06-07, 08:31 PM
  3. Scottoiler
    By btbloke in forum Mechanical Advice
    Last Post: 23-05-07, 04:47 PM
  4. Scottoiler
    By boboneleg in forum Mechanical Advice
    Last Post: 22-04-07, 04:12 AM
  5. Scottoiler
    By ChrisH in forum Transalp
    Last Post: 25-06-05, 08:44 PM
