Results 1 to 10 of 11
Thread: bodgers windscreen
    tendays's Avatar
    tendays is offline Senior Member
    Jun 2006
    birmingham uk
    bodgers windscreen
    I was getting blatted by the wind on fast roads on the way to the trails on the DRZ, so started lookin for ideas. The old GS650 Dakar screen makes for a good bolt-on but they're difficult to find. So...
    I bought some 4mm clear lexan (polycarbonate), a cheap heat gun and some M6 nuts and bolts. The lexan is the kind with UV resistance so it won't go yellow. It's very tough, so you can belt it with a hammer without breaking it, and thermo formable, but not scratch resistant. So I did all bending and drilling before removing protective films. And then scratched it anyway, bejesus.
    No photos of WIP but basically I made a cardboard mock-up, cut the shape out of lexan using a hacksaw, sanded the edges a bit and gave it a quick polish with an Aldi dremel (thanks Kymmy). Then ruled a few lines for bends, had a quick practice with an offcut (which bubbled shortly after going bendy) and started bending around an olive oil bottle (taller with a smaller radius than wine bottle). The sharper bends at the corners were done with a borrowed workmate and two short skirting board offcuts. And the lip using an offcut of kitchen cornice with a curved edge.
    Then I drilled the screw holes, going slowly to avoid melting. I screwed this up (sorry bad pun) quite badly so screen isn't mounted exactly symmetrically. But not too bad for a first go.
    As you can see there are only two mounting points so the screen can be tilted well forwards for offroad decapitation avoidance, or back for less drag / turbulence.
    In future I might add some brackets to handlebar or forks to make it more rigid but for now I'll see how it goes.
    Costs:
    £15 lexan
    £0.59 nuts n bolts
    £17 heat gun
    /td
    dl650k7
    drz400sk5
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: bodgers windscreen
    Nice job
    its screaming for stickers though
    a nice Dakar in etched look would suit applied from the back for ease of cleaning
    tendays's Avatar
    Jun 2006
    birmingham uk
    good idea sir
    /td
    dl650k7
    drz400sk5
    veodoble is offline Senior Member
    Nov 2008
    Barcelona
    perfect, man!
    I think I'll borrow your technique, since a similar idea has been circulating my mind as well, but hesitated about the procedures. Now I know how-to!
    congrats!
    Yahoo's Avatar
    Yahoo is offline Need a job
    Nov 2008
    Drifting...
    Quick question: Where did you buy the clear lexan stuff? Can you get it in any old diy store?
    And permission to copy your idea sir, see the missus's (mine really) drz needs some wind protection and yours is a most splendid idea, Whot whot!
    jasonbc's Avatar
    Camborne, Cornwall
    Absolute top quality bodging
    GASGAS TXT250 PRO 2006
    Paul-S's Avatar
    Jul 2007
    Runcorn, Cheshire
    Fantastic job
    tendays's Avatar
    Jun 2006
    birmingham uk
    lexan from fleabay.
    3mm might be better than 4 if i was doing it again.
    /td
    /td
    dl650k7
    drz400sk5
    stuart's Avatar
    Jan 2008
    lancashire
    nice job , I've never managed to bend Lexan without bubbles.
    Aprilia rxv 450 pile of scrap, got a refund
    Honda crf450x
    XS 700 Mercury Twin
    safehouse
    TLD 6/2010 Run For The Sun 15hrs 55 min all in
    TLD 6/2011 Two Towers 14hrs 56 min leisurely bimble
    Nice, it looks more professional than a bodge
  1. my bodgers
    By mick in forum Bodgers Corner
    Last Post: 27-01-08, 08:48 PM
  2. NX250 Windscreen
    By gepettobrent in forum Dominator / FMX
    Last Post: 07-08-07, 02:37 AM
  3. Windscreen...
    By groselha in forum Transalp
    Last Post: 30-04-07, 09:21 PM
  4. Changing the TA Windscreen
    By Stephen in forum Transalp
    Last Post: 18-12-06, 11:28 PM
  5. Windscreen Dilema
    By usatic in forum Africa Twin
    Last Post: 02-12-05, 09:09 PM
