Results 1 to 9 of 9
Thread: BRICO: 5 cm more for screen
    Mototrell is offline Junior Member
    Aug 2009
    Zaragoza (Spain)
    Good afternoon.
    I made a small supplement (5 cm) for my screen, with the simple materials: plastic, screws and tweezers.
    Tweezers in screen.
    Plastic in tweezers. Now we paint the holes
    Completed. Front.
    Back.
    Weight.
    On the screen.
    Side view.
    The plastic has 5 cm high and 20 cm wide. The tweezers are small but very strong.
    At 140 km/h in highway no problem and better air flow for the helmet: less noise.
    Bye.
    Alba's Avatar
    Alba is offline Senior Member
    Fife, Scotland
    Re: BRICO: 5 cm more for screen
    Nice one .. (do not be surprised if the mods move this to bodgers corner)
    In the UK we call the tweezers bull dog clips, I'm surprised they are strong enough. The plastic attachment looks to have a very good profile, where did you get that from ???
    Varadero Rocks
    Aug 2009
    Zaragoza (Spain)
    Quote Originally Posted by Alba View Post
    Hello.
    For my bad english, I use habitually the Google's traductor: he says "tweezers".
    Yes, the bull dog clips that I speak are small but very strong.
    Is difficult open this with one hand.
    I have other bull dog clips more great for others tests.
    The plastic attachment is a bit that a old screen from Transalp 600.
    But is simply to work with "policarbonato" and "metacrilato". You can to cut with a small saw and to bend with hot.
    This page is in spanish, but is possible you understand something:
    Metacrilato y Policarbonato, tecnicas de trabajo caseras
    I had bend something plastics into de oven from my house (my wife was out in this moment, hahaha). You put the oven at 150ºC during a few minuts.
    You test: if the material is strong and it is not posible to bend... more time into de oven.
    Caution: in this moment the plastic ir very hot. You need a gloves.
    Good luck.
    Very nice adaptor, you must be quite tall too need the raise the screen.
    Lumiya's Avatar
    Ziost
    Would we ever do a thing like that
    Aug 2009
    Zaragoza (Spain)
    No really. I have 1,84 high.
    The problem is the airflow impact in my eyes and made too noise and movements in my helmet.
    I need to down the head some centimeters.
    Thanks this suplement i need down the head 5 centimetes less.
    I will test with a old helmet's screen with 10 centimeters, for example (no more, the motorcycle's screen moves too much).
    veodoble is offline Senior Member
    Nov 2008
    Barcelona
    Muy bueno!
    Congratulations for your fine ideas! I suppose you own a 650 TA, and you've fitted the long screen, don't you? I'm exactly as tall as you are, and I wonder if you could explain me the pros and cons of changing the screen. I usually don't find incoming wind so annoying, but would like to check if longer screens are really an improvement.
    Si no entiendes algo me lo dices!
    Salud / Cheers
    Aug 2009
    Zaragoza (Spain)
    Hello Veodoble.
    Yes, my work is on a 650 Transalp.
    She has a high Givi screen.
    This screen removes all the air then impact in my body, but send the turbulent airflow to helmet's screen.
    In the helmet I have noise and vibrations very annoying.
    I think: one supplement will send the airflow above my helmet.
    The problem is the Givi screen is not very strong for put in top one big supplement. I have a small supplement for have not problems.
    With a small motorbike's screen the turbulent airflow impact on my body but the airflow that impact on my helmet is without turbulent. Less noise and less helmet's movements.
    For my is very difficult to write (and to read) in english, but i want to do it for learn.
    Is possible the english boys will think: horrible. Sorry.
    Regards for all.
    PD.: How can I to send a private message to Veodoble?
    Nov 2008
    Barcelona
    Hi Mototrell, I think we can't send between us private messages because we're not subscribed users. No problem, you can email me.
    -puedes enviarme un correo a hectorARROBAveodoblePUNTOnet-
    If you ever come to Barcelona in the next weeks, call me and we can have some beers!
    cheers
  1. Givi screen or MRA screen with winglet ?
    By LUNLUNZAI in forum Varadero
    Last Post: 24-07-09, 11:32 AM
  2. flip screen or touring screen ?
    By Dominic_the_TA in forum Transalp
    Last Post: 20-03-09, 11:10 PM
  3. Tall screen or screen spoiler?
    By McFly in forum Africa Twin
    Last Post: 18-10-07, 07:00 PM
  4. Screen?
    By Extremist in forum Africa Twin
    Last Post: 01-08-07, 10:03 PM
  5. Screen this!
    By pooh in forum Africa Twin
    Last Post: 30-08-06, 02:40 PM
