Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Look mommy, look what I've made!!!
    scarfacehugo's Avatar
    Jul 2008
    London
    Re: Look mommy, look what I've made!!!
    Quote Originally Posted by 1gear1brake View Post
    What do you mean 'push it back'? Africa Twins don't break down do they?
    They dont (unless it's some kind of voodoo in the ignition barrel area) but i do like to park it with the front wheel facing the exit and these dont come with reverse. Learnt it from James Bond's movies. He always parks facing the exit... you never know when a quick exit's needed
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    thats a fantastic looking lob, well done.
    i hate to be devils advocate but isnt there a major weak spot in the two upper bolts, where the tube has been scalloped out for the flat washers? i wouldnt be surprised if it fractures there after very long with a load.
    i hate to say something because its great and you should rightly be proud as buggery with it, please dont think im dissing your rack
  4. #13
    Jul 2008
    London
    Yes, the tube has been scalloped for the bolts because unfortunatelly those two bars run exactly on top of the holes where the bolts go.
    It took me a while to get to this solution, but I'm more than sure that'll hold. I dont carry a top box, only a drybag with light camping stuff such as sleeping bags, mats, and light clothing. I like to keep the weight low in the bike (easier to pick it up)
    The pipe was cut and I used another bit of pipe (bigger diameter) to reinforce the cut one in a 90º direction (hard to explain). Then a 3mm stainless washer was welded to the bottom to hold the whole thing down. If a plastic rear carrier holds , so will this.
    I appreciate your concern , Dave, but in opposite to Carbon Fiber, I've been fabricating steel for a loooooong time.
    Dont worry, if it brakes, I'll be the first to post it
  5. #14
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    Quote Originally Posted by scarfacehugo View Post
    jobs a good'un then, youve obviously thought it through, nice one.
    wish i could weld that well, all i ever made was lines and lines of rats**t.
  1. This is what it was made for :)
    By Blindboy in forum Africa Twin
    Last Post: 14-09-09, 05:03 PM
  2. made it just...
    By raymo in forum Meet Ups / Rideouts
    Last Post: 22-02-09, 09:06 PM
  3. come to mommy......
    By Jenna in forum Other Bikes
    Last Post: 27-08-07, 10:06 PM
  4. i made a grease gun
    By shnesdi in forum Transalp
    Last Post: 01-02-07, 10:04 AM
