Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Tube bending
    Lumiya's Avatar
    Ziost
    Re: Tube bending
    We ourselves use the bottom version for bending pipe upto 22mm (you must get the perfect size former otherwise the tube deforms and also you may have to pack it with sand to stop collapse.
    We also have another tube bender but that one we use for items as large as scaffolding (2-3inch)
    thetimkirby is offline Senior Member
    Dec 2008
    anglesey
    Re: Tube bending
    Hi Snaphappy,
    Forgive me if this is a dumb question, but have you tried hiring one? We do steel pipe up to two inch occasionally, but not often enough to be worth buying a hydraulic bender, so we hire one. But for 15mm pipe, its a bit of overkill.
    If you've access to a good blowtorch or small oxy-acetylene kit, try Kymmy's suggestion of packing with DRY sand, and anneal before bending. I have a simple tube bender (first type you showed) and this is capable of bending thin-wall steel with care. There are some cheap ones around which won't bend plasticine, so check the thickness of the former walls.
    Steel pipe is cheap enough, give it a try.
    Tim.
  4. #13
    jasonbc's Avatar
    Camborne, Cornwall
    Re: Tube bending
    Quote Originally Posted by Snaphappy View Post
    I want to make my own rack and need some advice from the pros
    what sort of bender is up to the job I only want 15mm tubing so dont want to fork out hundreds just to play with once or twice
    would this be strong enough (am I strong enough)
    Or should I be looking looking at Hybollic or one of these on the second hand market
    Go to a reputable plumbers yard my local does pipe benders for 15 & 22mm for less than £30 plenty enough if your an amateur or only want to use it a few times
    www.plumbase.co.uk/
    GASGAS TXT250 PRO 2006
  5. #14
    datsun fan's Avatar
    datsun fan is offline Senior Member
    Jan 2008
    south coast
    Re: Tube bending
    If you have electric glue - hunt around - usually you can find something to adapt - some will recall my previous thread about making pannier rails from old chair legs - no bending required!
    From what was left - (it's 2mm wall thickness same as Touratech), I knocked up a rear rack - it can be easily done once the raw material is found! ( there appears to be a distinct lack of places to sit at work!)
  6. #15
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Tube bending
    Well I bit the bullet and bought a tube bender
    €150 new from some mush on fleabay.de
    it worked a treat for 16mm tubing with a 1.5mm wall thickness
    I've started making my racks had a few lessons from youtube and went for it
    screwed up a few corners but got there in the end, glueing them all together now, and hopefully by the weekend be ready to cut and refitt the exhaust
    (thats getting welded by a pro)
  7. #16
    jasonbc's Avatar
    Camborne, Cornwall
    Re: Tube bending
    They look very neat and tidy pitty pipe bender was so expensive
    Rothenberger Pipe Bender 15, 22mm - Screwfix.com, Where the Trade Buys
    Rothenberger MicroBender 6-10 mm Pipe - Screwfix.com, Where the Trade Buys
    Ebay not as cheap as people think
  8. #17
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Tube bending
    Had a look at the cheap ones and thought this is better value for money, comes with a choice of three diameter formers from 4mm to 22mm I ordered
    12mm 16mm 18mm
    will probably sell it on when I'm finished
    Rohrbieger und Holzspalter Bauanleitungen - Diashow
  9. #18
    jasonbc's Avatar
    Camborne, Cornwall
    Re: Tube bending
    12mm 16mm 18mm
    Does look a sturdy peice of kit
  10. #19
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    Re: Tube bending
    it does look a good bit of kit. i was going to say you can simply buy pre bent sections and offcuts cheap and weld them up but im too late, your up and running
  1. aluminium bending in/near London
    By Whealie in forum Chatter
    Last Post: 21-11-08, 08:56 PM
  2. You Tube
    Last Post: 18-12-07, 09:55 AM
  3. to tube or not to tube?
    By jabba in forum Wheels, Tyres & Tubes
    Last Post: 03-06-07, 08:52 AM
  4. bending metal
    By squirrelciv in forum Mechanical Advice
    Last Post: 31-10-06, 07:34 PM
