Results 1 to 10 of 19
Thread: Tube bending
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Tube bending
    I want to make my own rack and need some advice from the pros
    what sort of bender is up to the job I only want 15mm tubing so dont want to fork out hundreds just to play with once or twice
    would this be strong enough (am I strong enough)
    Or should I be looking looking at Hybollic or one of these on the second hand market
    Re: Tube bending
    Get The cheapest one. The top one could be wedged between steps to give you better leverage.
    scarfacehugo's Avatar
    Jul 2008
    London
    Re: Tube bending
    Quote Originally Posted by Snaphappy View Post
    Please, please, please dont go for these.
    If you pay close attention, the pipe is copper. These wont bend steel. They're cheap because they're made of white metal(very cheap alloy) and they break under pressure.
    I've got 2 of the basic model and one of them is broken for trying to bend ally pipe. There is no cheap way to bend steel. Second hand proper pipe bender is the way to go.
    twistgrip is offline Senior Member
    Jan 2010
    Just outside Rugby on the M1 side near where the big masts used to be.
    Re: Tube bending
    Once the tube is bent do you have the means to weld/braze it together? I'm a pretty handy sort of bloke but the last time I needed a carrier I got a Rentec one off evilbay for 20 quid. No outlay, fitted well and was robust. No real sence of achievment but an instant result. Weigh up the costs and what you save will pay for a day out.
    Bolton, Lancs.
    Re: Tube bending
    Top one is for copper pipe
    Bottom is conduit bender, that will do it, but even second hand ones are not cheap.
    stuart's Avatar
    Jan 2008
    lancashire
    Re: Tube bending
    depends on the gauge of the tube, I use the top one with 15mm alloy tube as the dies in my hydraulic bender are to large
    Aprilia rxv 450 pile of scrap, got a refund
    Honda crf450x
    XS 700 Mercury Twin
    safehouse
    TLD 6/2010 Run For The Sun 15hrs 55 min all in
    TLD 6/2011 Two Towers 14hrs 56 min leisurely bimble
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Tube bending
    Its all for a project that I still dont know if it will work
    I'm fitting VTR exhausts to the Varadero so they mount below the panniers, with loads of plastics cut away I can mount Alloy panniers narrower than the bars.
    But I need to to make exhaust mounting brackets, and mounts for the tinker tins
    I've got electric glue but cant stick alloy, I thought about making a copper template and asking a metal fabricator to make a steel copy but that seems longwinded and will probably cost more than if I get a bender
    barkingbiker's Avatar
    barkingbiker is offline Barking. Totally.
    Jan 2009
    kenilworth
    Re: Tube bending
    Try Protopipe in Coventry. Protopipe Tube Manipulation Contact Us They specialise in one-off pipe fabrication and bent and welded up some rectangles for pannier frames for our TA's for 40 beer tokens. Nice.
    BB
    OBE
    OBE is offline Junior Member
    Nov 2009
    Fareham Hants
    Re: Tube bending
    Have you thought of hiring a pipe bender?
    4 wheels move the body 2 wheels moves the soul
    Shox Dr is offline Senior Member
    Jul 2009
    East Yorks
    Re: Tube bending
    Both of those benders will work with the correct wall thickness in seamless tubing (2mm+). The biggest problem you will have is the CLR (Centre Line Radius) will be large so you will end up with big corners.
    I've just spent 180quid on a 5/8 x3CLR die set, for my Hydraulic Bender. But then my set up cost around 3k. you get what you pay for
  1. aluminium bending in/near London
    By Whealie in forum Chatter
    Last Post: 21-11-08, 08:56 PM
  2. You Tube
    Last Post: 18-12-07, 09:55 AM
  3. to tube or not to tube?
    By jabba in forum Wheels, Tyres & Tubes
    Last Post: 03-06-07, 08:52 AM
  4. bending metal
    By squirrelciv in forum Mechanical Advice
    Last Post: 31-10-06, 07:34 PM
