Results 1 to 10 of 16
Thread: crf,230,speedometer.
    Rjc
    Rjc is offline Junior Member
    May 2009
    Wrexham
    Hello all of you out there. I'm a new boy on the block and found this forum by accident.
    I'm pretty well through a project with the CRF230. I've scrapped the "lighting kit" that came with the bike and replaced it with xr400 headlight, shroud and speedometer. Speedo cable from xr200 fits a treat. The plastic gear box on the spindle has been modified with an alloy sleeve and that's fine. There is a key way in the hub to take the round washer drive key from the xr 400 and the seal fits. All is well so far.
    Now the crunch. The plastic gear box scrapes on the edge of the hub and when this bike gets in the N Wales bogs it will simply be destroyed. My question is......Will the front wheel from the xr200 fit into the forks of the crf230 and provide a gap between the plastic gear box and the hub.
    I believe it will, but I need to find someone locally, 50 miles say from Wrexham with the xr200 where I can give it the beady eye and measure the spindle.
    If it works and I think it will......big success.
    Anyone out there that can help I would b pleased to read the replies.
    Remember, best keep the round rubber things at the bottom, close to the floor....most of the time.
    Rjc
    Ratcatcher is offline Member
    Sep 2007
    Anglesey, North Wales
    Re: crf,230,speedometer.
    Should have got a Serow
    hondaxrnut is offline Senior Member
    Oct 2008
    somerset
    i have a 2005 crf230f, which i bought new, that was fitted with a cycle type speedo, which works fine and after 4 years of off roading still works ok, just needed some new batteries.
    the same thing can be bought from halfords for about £20
    i can set up some pics to show you
    shaun
    kempouk's Avatar
    kempouk is offline Senior Member
    Jul 2007
    loughton essex
    Quote Originally Posted by hondaxrnut View Post
    shaun
    my front wheel has no speedo guts inside it, im looking at other options, could you show me the pics please?
    Oct 2008
    somerset
    yes i will try tomorow.
    Oct 2008
    somerset
    hi, ,managed to take some pics of the crf speedo.
    the sensor pick up is mounted on the rhs lower fork,
    the sensor is mounted on the spokes near the sensor pick up.
    the instructions says that the 2 should be closer but they still work ok at this distance.
    wiring run up fork leg, using the original cable ties and some new ones.
    speedo bracket just goes around the handlebars,
    and speedo is mounted just in front of the handlebar pad.
    if you need anymore advice just let me know, i hope this helps.
    kempouk's Avatar
    Jul 2007
    loughton essex
    cheers fella, that looks fine to me, if i cant get the guts for my front wheel i shall go down that rout.
    kempouk's Avatar
    Jul 2007
    loughton essex
    a couple of things, could you measure the distance from the sensor to the pickup, and also the length of the wire please.
    i just bought the kit and cant get it no where near the handlebar, i got it fixed under the h bar but the cable on the censor gets me no where near the hub, I'm half way up the spoke and the sensor is about 30mill from the pickup
    and as the spoke is at an angle the the pickup seems to be pointing upward slightly.
    trust my luck eh.
    kempouk's Avatar
    Jul 2007
    loughton essex
    hmmmm, i got it working at last.
    oh the wonders of lego eh.
    Oct 2008
    somerset
    glad to see you have made something to fit
    the distance they tell you (from pick up to sensor) in the manual can be bigger and it will still work, mine is twice as far as they recomend.
    shaun
  1. speedometer
    By Bassman in forum Africa Twin
    Last Post: 11-10-09, 07:19 PM
  2. speedometer
    Last Post: 11-01-09, 08:05 PM
  3. where to get a speedometer ??
    By iulian in forum Transalp
    Last Post: 15-06-08, 10:41 AM
  4. Speedometer
    By rossco in forum Africa Twin
    Last Post: 24-12-04, 04:11 PM
  5. Speedometer problem
    By Krizz in forum Africa Twin
    Last Post: 18-10-04, 01:31 PM
