Results 1 to 10 of 18
Thread: Car bike rack for crf450
    Africa Twin's Avatar
    Africa Twin is offline Junior Member
    Apr 2009
    Swansea
    Hi everyone
    I been looking at towbar mounted bike racks such as the one from dave cooper and was after some advice if anyones got one. I have a volvo s60 to which i just had a new towbar fitted it seems a pretty sturdy one but says max nose weight of 75kg i imagine this is recommended so can i put a 114 odd kg bike on it? are there any towbars that take this weight?
    If i fit one and get away with the bike tho how can i still tow my caravan as this probably adds about 50kg?????
    cheers
    scotsy's Avatar
    scotsy is offline Senior Member
    Jul 2009
    Lancashire, UK.
    Re: Car bike rack for crf450
    I did once take the gas bottle box off a caravan A-frame and bolt a channel across to carry a crosser but you couldn't do tight turns without damaging something
    I also once used a spectacle rack (dave cooper) and bought an 'extender' to go behind the towball so i could still tow the caravan with a bike in the rack
    I WOULD ACTUALLY RING DAVE COOPER UP FOR ADVICE AS THEY HAVE PROBABLY COME ACROSS YOUR PROBLEM WITH PREVIOUS CUSTOMERS sorry, caps lock on accidentally
    Bolton, Lancs.
    Put a door in the back of the caravan, . . put the bike in the caravan. . . . . . Seemple
    Neilios is offline Senior Member
    Nov 2008
    Co. Durham
    You could do it but I would not say its correct or a good idea and if you have a crash I am sure your insurance company would be very interested in how the vehicles steering and breaking was impared!! I used to do it with a trials bike and could tell the difference as it was also a FWD car, Bike 75kg, rack 10kg and tools petrol and kit!! it all adds up. food for thought. Sorry to sound negative but be carefull.
    Lumiya's Avatar
    Ziost
    If a copper sees the bike on a tow bar like that then you are likely to be pulled over and if above the rated weight of the towbar you can get seriously fined..
    Why not get a small bike trailer for use when you done't have the caravan and then get a caravan bike rack?? But be warned most of the caravan bike racks are designed for little 50-100cc bikes.
    The max ball weight is desgned so you don;t snap off the ball, you might think that your bike is only a bit above the weight limit but when you go over any bump the inertial weight can be anything upto 3-4 times the original weight. Hence when you load up a caravan you place everything over the central wheels or very slightly behind them so you;re not putting undue stress on the ball
    switch's Avatar
    Feb 2009
    Romania
    The tow hook must be designed to support at least 125kg itself. Then the bike rack must be designed for 125kg as well.
    A CRF450 is about 118 without fluids, so with an empty tank it should be under 125.
    Lumiya's Avatar
    Ziost
    Quote Originally Posted by Africa Twin View Post
    Quote Originally Posted by switch View Post
    All tow hooks these days have to have the weight they're designed to comfortably load, this weight will also be the one used by the police..
    Also the tow hook sounds like it's just standard and not a heavy duty one..
    Also our volvo estate has a maximum rear loading of 250Kg over the back wheels. If you take that weight as standard and then extend it outwards any weight directly on the back of the vehicle will be amplified over the back wheels.. Personally I'd stick with what the towbar says as you'll either tear off the ball (yep seen it happen), shear the mounting bolts or knacker up the suspension/mounts.. Or at very least reduce the loading on your front tyres...
    Remember that tow balls are made to tow, not to carry
    Critch's Avatar
    Critch is offline Hi SuperNintendo Chalmers
    May 2007
    Bury ,Manchester,Uk
    Very valid point !
    Boring bit I found out on my last MoT:
    Towbars and the MOT Test
    From 27th April 2009 towbars and their attachment to the vehicle will become part of the MOT test.
    Below is a guide to all you need to know, as provided by The Vehicle and Operator Services Agency (VOSA)
    Why have towbars been made MOT testable?
    All European Union member states are required to have a periodic inspection regime in place for the majority of vehicle types. For private vehicles used in Great Britain, this requirement is met by the MOT test. It is mandatory for such tests to include items prescribed in the legislation, which includes towbars, as they are considered essential for road safety.
    Will the check apply to all towbars?
    The test will apply to any type of towbar fitted to the rear of any vehicle in Classes 3, 4, 5, & 7. It does not include towbars fitted to motorcycles as they are not covered by this legislation. Nor does it include the emergency towing eye which is fitted to the majority of modern vehicles.
    If the tow ball is not fitted at the time of test, only the security of attachment of the towbar brackets and the condition of the vehicle structure will be assessed.
    However, where a towbar has been deliberately rendered unfit for further use, so that the simple refitting of a ball, pin or eye is no longer possible, any remaining components will no longer be considered as a towbar for the purpose of the test.
    Will fixed covers or panels be removed?
    No covers or panels will be removed to facilitate the inspection of any components, including tow ball covers. Components hidden behind bumper bars for instance, will be tested as far as is practicable. However, it may be necessary to inspect some components from inside the luggage compartment, including lifting of loose fitting mats or carpet.
    Are Type Approval markings included in the check?
    There is no requirement for the tester to check for Type Approval markings and the towbar will not be failed if they are not present.
    Are the towing electrics included in the test?
    The electrical wiring and socket are not part of the test. If there is an obvious fault the tester will simply advise the vehicle presenter.
    What about quick release or detachable towballs?
    Towbars with a quick release mechanism will be checked for excessive play between the detachable tow ball and its receiver socket. Free play in the tapered swan neck fitting of up to 3mm movement measured at the ball end is acceptable.
    The check will also include that the release mechanism secures the tow ball as intended.
    How will the towbar be tested?
    The inspection will consist of a visual assessment of the towbar assembly for excessive corrosion, fractures and damage as well as wear of the tow ball, jaw, hook or eye. It will also include a check for the presence and security of retaining nuts, bolts, pins etc. as well as any necessary locking devices, such as split, or 'R' pins.
    Checks that the towbar assembly is securely attached to the vehicle structure include that mountings, supports and fixings are of an appropriate size and type, which may involve pulling on the towbar to check for the suitability of materials used.
    The condition of the vehicle structure within 30cm of all towbar mounting points will be checked for any deliberate modification, corrosion, damage, fracture or inadequate repair, which affects the strength of the structure to the extent that the security of attachment of the towbar is significantly reduced. If it is, this will result in failure.
    How will wear be assessed?
    Wear in a pin, jaw or hook will be regarded as excessive if the thickness of the metal at any point is reduced by more than 25% of the original thickness. Pin locating holes will be rejected if they are worn or elongated by more than 25% of their original diameter. These criteria also apply to pins and brackets for any height adjustment or swivel devices. For tow balls the amount of acceptable wear is considerably less, therefore a tow ball will be rejected if a visual assessment indicates that the tow ball is obviously excessively worn.
    What about height adjustable towbars?
    On height adjustable or swivelling towbars, additional checks will be necessary to check for presence, security and excessive wear of locating or swivel pins and
    brackets. Any locating or swivel pin retaining devices will also be checked for presence and security.
    Inspection Manual Criteria
    Method of Inspection
    • Visually assess the towbar for wear and pull on the towbar and/or its mountings to check for security, corrosion, fractures or damage.
    • Check the towbar assembly is attached to the vehicle structure using mountings, supports and fixings of an appropriate size and type
    • Check the presence and security of:
      a. retaining devices e.g. nuts & bolts
      b. locking devices e.g. split pins, 'R' pins. Note: Some locking devices are not obvious. In such cases, the vehicle presenter should be advised of any evidence of disturbance or insecurity.
    • On detachable tow balls:
      a. check for play between the tow ball arm and its receiver socket
      b. visually assess the condition of any quick release mechanism.
    • On height adjustable or swivelling towbars, check:
      a. for presence, and security of locating or swivel pins
      b. locating or swivel pins and brackets for excessive play or wear
      c. locating or swivel pin retaining devices for presence and security.
    • Check the condition of the body and chassis in the vicinity of the towbar mountings.
    Reasons for Rejection
    • A towbar component insecure, fractured or excessively: •worn •corroded, or •damaged.
    • Towbar assembly is attached to the vehicle structure using a mounting, support or fixing which is obviously of an inappropriate size or type
    • a. retaining device missing or insecure
      b. locking device missing, insecure, inadequate or damaged to the extent that its operation is impaired.
    • a. Excessive play between a detachable tow ball and its receiver socket
      b. a quick release mechanism that does not secure the tow ball arm as intended.
    • a. A locating or swivel pin missing or insecure
      b. excessive play or wear in a locating or swivel pin or bracket
      c. a locating or swivel pin retaining device missing or insecure.
    • Any deliberate modification, excessive corrosion, damage, fracture or inadequate repair of a load bearing structure or supporting panelling within 30cm of the towbar mountings, which affects its strength to the extent that the security of attachment of the towbar is significantly reduced
    More Information
    This article is meant only as a guide, and is correct at the time of publishing on 24th May 2009. You can download the Towbar MOT information as a PDF file here
    For more information, or if you have any questions, please visit the VOSA website or the DirectGov website
    bazza's Avatar
    bazza is offline Senior Member
    Apr 2007
    Catterick, North Yorkshire
    I have a Kia Soronto, how do i find out the max weight as i am getting a rack for the Beta as not to over load it, The car will be fine its just the tow bar atachment that concerns me now.
    97 @T, Silver with 12v socket, crash bars, givi luggage racks, home made panniers, fogs, stebel nautilus and TKC 80s.
    2000 Beta Rev3 250 (My little toy).
    Safe House with Garage, tools and Tea
    webbo is offline Junior Member
    Jul 2010
    yorkshire
    acoording to the local traffic cop, the nose weight is a manufacturer's recommendation, the police would only be interested in the axle weight.. so a crf on the back is no worse than having two fat birds sat on the back seat..
    but... if the rack or tow bar broke, they could prosecute for dangerous load... so all in all... you might be safer with the two fat birds after all.
  1. Top Box Rack
    By Frad in forum Travel
    Last Post: 07-08-10, 12:45 PM
  2. top box rack
    By PHILinFRANCE in forum Chatter
    Last Post: 03-01-09, 07:14 PM
  3. Annettes new bike rack
    By Chunk in forum Bodgers Corner
    Last Post: 03-04-08, 06:21 PM
  4. Rack n Boxes.
    By stanbloke in forum Varadero
    Last Post: 19-09-07, 03:38 PM
  5. Rack Compatability???
    By Cabby in forum Mechanical Advice
    Last Post: 31-03-07, 03:07 PM
