Re: advice on an old CR125
Fiches here, if this is the correct model:
honda water pump partsmanual fiche cr125r 95 cr125
Bung the part numbers into the parts search at David Silver Spares and that'll give you an idea of what's available and how much.
The likely damage will depend on what's wrong. If it's just the seal gone it's an easy fix. See if you can get more info. If the motor has overheated as a result of the pump issues, you could be in for a whole heap of trouble.
