Results 1 to 2 of 2
Thread: more help needed please
    sportline is offline Junior Member
    Jan 2009
    cardiff
    Hi again,
    im looking for a bit of advice on this 96 cr 125 i have. ive put the engine back together but have a few probs still.
    The head gasket, the one right at the top where the top plate/sparkplug bit bolts on, in the pack of gaskets i bought for the bike its a sheet metal gasket, not paper like the others, i kicked it over and it started, but it was leaking out the sides, all around, as if the gasket wasnt working.
    have i done something wrong or should there be another gasket in there with the metal one.
    Scouser's Avatar
    Scouser is offline Junior Member
    Sep 2009
    Dorset
    Re: more help needed please
    Normally the gasket is a steel centre with material on either side. if it is leaking,the head may be warped and you need to get it leveled off. you can try putting very fine emery paper or wet and dry with oil on it and face it off on a perfectly level surface, something like a piece of glass. ensure you have your torque wrench set to correct setting.
  1. Help needed
    By StumpyFingers in forum Chatter
    Last Post: 25-07-09, 09:32 AM
  2. help needed
    By tongek in forum Africa Twin
    Last Post: 22-08-08, 06:12 PM
  3. Help needed
    Last Post: 26-11-07, 09:58 AM
  4. DIY help needed
    By Breeze in forum Africa Twin
    Last Post: 25-09-06, 09:34 AM
  5. Just what we needed to know
    By SteveWilko in forum Chatter
    Last Post: 20-09-06, 06:51 AM
