Re: crf 250 x reliability
Originally Posted by
jasonbc
The valve springs are a set length and are compression springs so unless the springs stretch aswell how would they allow the valves to travel further than there original stroke
The springs hold the valves tight closed as they are fitted in compression. They are longer when not fitted than when they are fitted.
So, when the valve is sitting in the head with no pressure on the top, it is being held in place by the valve spring pulling the top of it and at the bottom it is held hard against the valve seat. At high revs, the valve is being repeatedly slammed shut. The cam lobe doesn't ease it on to the seat completely smoothly. The valve hits the seat with some force and the head of the valve stops. The rest of the valve, spring etc has momentum and this all pulls on the top of the valve in a stretching motion as it all stops too.
After thousands and thousands of repetitions of this pulling motion, the valve can stretch. Sometimes the head fractures and falls off and that creates a right mess.
