special crf narrow chain??
Results 1 to 6 of 6
Thread: special crf narrow chain??
    begazzz's Avatar
    begazzz is offline Member
    Jun 2010
    ilfracombe
    Hi people,
    I bought a Renthal chain and sprocket kit and after 200 miles with 4 proper chain off cleans and maintenance one half of the split link broke and chewed up the sprocket so time for replacement.
    I dont want a renthal again as they are made of cheese so think im gonna go for steel as 5 kilos of mud will put pay to any bling light weight kit.
    after reading up you are supposed to use a £100 narrow chain for the crf to prevent it hitting expensive bits but has anyone else done this or just stick with std chains????
    ta...
    Jakey is offline Senior Member
    Nov 2011
    Bedfordshire
    They rub the crankcase that's why you need a narrow one.
    Running sprocket backward spaces it out enough to clear.
    A t ring chain is recommended if I remember. Best to get one
    begazzz's Avatar
    Jun 2010
    ilfracombe
    Re: special crf narrow chain??
    that seems like a bit of an oddball thing to do for such a maintream company..... any advice on where to buy from that might be cheaper than honda
    Nov 2011
    Bedfordshire
    DID make them. So from them.
    Il have a look for part number later
    blade72003 is offline Junior Member
    May 2009
    NE London / essex
    Just bought a std did o ring and it dose not rub but if it did would just need a 2mm washer behind the front sprocket Fastway Countershaft Spacer: CRFs Only - Your Source For Honda CRF Parts, Accessories and Information... hope that helps
    ritosxf's Avatar
    ritosxf is offline sfx wheels
    Jul 2009
    walsall , well cheslyn hay to be exact , jnc11 m6
    did chains available from stock at ORO Online Store - Off Road Only Ltd
    520 d-z 120 link ,,,, part number 30-851
    520 vx x ring ,,,,, part number 30-803 120 link
    oem for crf250x and crf 450 x did 520 vt2 x ring chain ,,,, 116 links part number 30-831
    spare split link part number 30 - 830
    hows that eh
  1. Special K
    By Whealie in forum Chatter
    Last Post: 26-06-11, 07:02 AM
  2. BMW HP2 Special
    By Kjell Lindberg in forum BMW
    Last Post: 03-11-08, 07:07 PM
  3. BMW Special
    Last Post: 31-10-08, 08:14 PM
  4. narrow exhaust
    By Overland Ollie in forum Africa Twin
    Last Post: 19-05-08, 09:35 PM
