Fork springs
Touratech offer the Wirth springs
All years 01-040-0465-0
Hagon
All years 500-103-00 (7.5wt oil, 140mm air gap recommended)
Rear shocks
Hagon
1988-94 M61065
1995 on M61071
Dirt Bike in Austria show the WP damper
1988-94 WP17.14.J9.49
1995 on WP17.14.P9.50
Hyperpro
1988-94 HO06-026S Type 040
1988-94 HO06-126S Type 041
1995 on HO06-027S Type 040
1995 on HO06-127S Type 041
Type 040 'Emulsion Type' rear shock with:
Rebound damping adjustment.
Spring preload adjuster ring.
Progressive spring.
'O' Rings for stroke adjustment.
Ride height adjustment.
Type 041 'GP Type' rear shock. Spec as above with the following additional features:
Remote reservoir with hose connection.
High speed compression damping adjustment.
Low speed compression damping adjustment.
Lock bolt for preload adjuster ring.
Technoflex
1988-94 55308-815-575 Standard
1988-94 55208-815-575 Remote reservoir
1995 on 55308-815-577 Standard
1995 on 55208-815-577 Remote reservoir
