Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: CHAPTER 2 - LUBRICATION
    squirrelciv Guest
    Personally I'd stick to semi synthetic. You have to bear in mind that the engine is partially cooled by it's oil and if revved hard they can burn up a bit too. If you do choose the mineral oil option, you would do well to change it every 1000 miles or it's going to burn and not protect things very well.
    Only my opinion mind, and all advise must be tempered with the certain knowledge that I'm a worry wart
    Rubberchicken's Avatar
    Amsterdam
    Indeed. Semi synth 10W40 is the safe option, full synth is overkill given the change intervals in an engine like this. Dunno much about mineral, no experience with that myself but a guy I know swore by the stuff for his old XT500.
    Basically you just have to play with the change intervals a bit, if the oil comes out black and smelly then you've left it in too long...
    Michel
    '89 NX650 -- R.I.P. -- Gone
  4. #13
    Confucious's Avatar
    Confucious is offline Senior Member
    Norway
    I think we have a majority here boys...I'll go for the semi....I love this site it's like the family some unfortunate bugger never had
  5. #14
    kaupo is offline Junior Member
    Jan 2008
    ESTONIA
    Re: CHAPTER 2 - LUBRICATION
    Greetings form Estonia! I am new to this forum and need a bit of help. Somehow I managed to lose my original oil dipstick during last oil change (I use RR stick with thermometer daily and it doesn't have level marks). If anyone could measure both the higher and lower level distance from the end of the stick, I'd be grateful! Didn't find this information anywhere, so thanks in advance!
  6. #15
    Amsterdam
    Which reminds me, I need to top up the oil!
    Be right back.
    *off to the shed*
    Michel
  7. #16
    Amsterdam
    Gotcha
    The high mark is at 8 cm. (I've put a little edge in it with a metal saw. It's more visible in daylight, though.) I haven't made a mark for the low, but it's 2 or 3 mm off the end of the stick if I recall correctly.
    Michel
  8. #17
    Jan 2008
    ESTONIA
    Hi!
    I'm adding an oil cooler to my RD08 dommie as an experiment, so I need to have some oil pipes made in order to not to ruin the original. Does anyone happen to know (or even be able to measure by any chance) the thread values on the oil pipe nuts. (The upper one is inside-threaded, and the lower on outside-threaded if I remember correctly. Can't do it myself, I'm parted from my bike til weekend.
    P.S. How do long-time users comment on this suggested oil change interval of 6000km by Valvoline?
    Valvoline Product Recommendation
  9. #18
    yellowpurple Guest
    Changing the oil every 2000 miles is a drag, but I would rather do that than risk a seizure (either engine or my own!). I would always stick to the manufacurers recommended intervals, the peace of mind is worth it in my opinion. I change my oil every 3000Km with a new (genuine) filter & even then the oil still comes out black! Cleaning the down tube guaze is a good idea every other oil change too (although it always seems clean to me). I use Silkolene 10W40 semi synthetic & would recommend it thoroughly. Seems to need less topping up than other brands I've tried.
  1. CHAPTER 8 - CLUTCH
    Last Post: 05-10-08, 08:21 PM
  2. CHAPTER 20 - WIRING
    Last Post: 29-07-08, 12:05 PM
  3. CHAPTER 11 - TRANSMISSION
    Last Post: 24-03-08, 01:09 PM
  4. X Ring Chain Lubrication
    By Ralphie in forum Mechanical Advice
    Last Post: 08-09-06, 03:04 PM
  5. CHAPTER 3 - MAINTENANCE
    Last Post: 05-09-06, 09:36 AM
