Results 1 to 10 of 11
Thread: Domi died on me??? : - (
    The Cosmic Lawnmower is offline Junior Member
    Jun 2006
    Isle of Wight
    As a newbie to Domi's any advice welcomed.
    I recently bought a '91 model, and was out enjoying a rideout in the sun today.
    Along the way we stopped in a small chalk pit at the side of the road and had a little off road blat up and down some of the slopes and bumps,
    I stopped for a breather after ten minutes (she's a big gal the Domi!), after which she totally refused to fire up. I thought I'd flooded her so left it for a while... still no luck, I tried bumping her down the fairly long hill from where the pit was situated... no go. I wondered if she'd got over warm riding around (it was pretty hot out today)? I used to have a Husky 510 that was a pig to start when hot.
    I locked it up and left it for a couple of hours to cool... then went back to it, still it refused to even fire . I ended up towing it home.
    Any ideas? I can't see why it would go from running perfectly to total no go
    There appears to be no mechanical probems, it turns over ok, just doesn't seem to want to fire.
    I'm wondering if the bumping around off road has dislodged some electrical component/wiring? I have a suspicion it's something annoyingly simple that I should be able to spot
    Anyway sorry to waffle on - but any advice most appreciated.
    Nigel
    lreal is offline Member
    Mar 2006
    Madrid, Spain
    don't know if it will be the problem
    i had lots of random dimo complete stop because the connector to the CDI was working NG
    initially i thought it was the connector,
    i welded the terminals --> random stop again
    the failure was internally in the CDI and the cause was i think that in some disassembly, someone installed CDI with the connection very close to the headlamp
    in that condition it vibrates against headlamp&connector, and some internal mis-connection can be made
    that was a crazy situation; random stop was really awful; finally, new cdi
    cheers
    Lorenzo .. Spain
    Mar 2006
    Sidcup, Kent
    Without wanting to sound stupid....
    You HAVE checked that there is enough go-go juice in the tank ? ..haven't you ?
    Jun 2006
    Isle of Wight
    Right... panic over!
    We're up and running again..... the no go was down to an acutely embarrassing incident with an unfamiliar kill-switch!!! Doh!!! How dumb do I feel
    Sorry to have bothered you guys.... <gets coat, and slinks away>
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Quote Originally Posted by The Cosmic Lawnmower
    LOL
    We've all been there!
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    Sharribee's Avatar
    Sharribee is offline Matron
    Jan 2006
    Wales
    In my house that would be described as a mabel momenet - I have lots of them
    DELILAH
    2010 F800 GS
    Rubberchicken's Avatar
    Amsterdam
    The no go was down to an acutely embarrassing incident with an unfamiliar kill-switch!!! Doh!!! How dumb do I feel
    I feel your pain...
    (Ever tried a stunt like that on a kickstart-only bike? Quite a workout, and another reason for a red face.)
    Michel
    '89 NX650 -- R.I.P. -- Gone
    squirrelciv Guest
    Oops
    Never mind matey (said through the snigger) we've all had simular
    Remember trying to start Dolly after she died on me one morning. First ran the battery flat, then bumped her down a hill (having pushed her up said hill first ) three times before noticing I hadn't turned the petrol on
    Mar 2006
    Sidcup, Kent
    LOL
    I think just about every body who has ever owned a bike with a kill switch has done that.
    At least YOU spotted it
    Jota is offline Junior Member
    Jun 2006
    Australia
    Confessional
    Before your confession I was wondering about something that happened to me.
    We set off on our big trip into the outback (see website below) and to be cautious, I disconnected the side-stand cut out switch on Andy's 93 Dommie. I didnt want anything to foul the wires in the rough and maybe cause a problem.
    So...I zip-tied the switch up out of the way.
    (You know what's coming....) Day one, happily blasting olong when BANG Andy's bike cuts out.
    Only after a methodical check of spark, fuel, WD40 over everything and much cussing did I think about that cut-out switch. The vibration had made it move into the 'stand-down' position, cutting the ignition when 1st gear is engaged.
    Seems obvious now.
    Doh.
  1. Domi Newbie
    By rikki1q in forum Dominator / FMX
    Last Post: 20-01-07, 04:00 PM
  2. Who said that Domi was not amphibian ???
    By lreal in forum Ride Reports and Pictures
    Last Post: 18-05-06, 08:54 AM
  3. Carb for 97 Domi
    By Frayed Dave in forum Dominator / FMX
    Last Post: 02-05-06, 07:41 PM
  4. Dog died....
    By ChrisH in forum Chatter
    Last Post: 04-04-06, 06:59 PM
  5. And then it just died...........
    By Dilbert in forum Africa Twin
    Last Post: 08-06-05, 02:09 PM
