Results 1 to 7 of 7
Thread: clutch cable problems
    dominatormike is offline Junior Member
    Jul 2006
    seaford
    Hi guys,
    could anyone help i have ordered a new clutch cable as the nipple had come off of mine. The nipple on the new one at the clutch end, is larger and the adjuster on the engine side of the cable is slightly different (mine has two nuts on a thread) and the new one has the two nuts but also has a nut fixed to the top of the thread which makes the cable too short
    The shop's tell me there is only one cable listed for the dominator but i seem to have a different one!! has anyone else experienced this problem or got a way round it?
    cheers mike[/img]
    i have a photo of the cables but i am unsure how to display them
    anton88's Avatar
    Did you buy it from a Honda dealer ?
    Jul 2006
    seaford
    no i've tried wemoto and busters ,do you think a honda dealer would be able to help?
    anton88's Avatar
    Worth a try - especially if you can take the old clutch cable along to make sure you get the right one.
    They may not have one in stock but can usually order stuff within a week.
    Jul 2006
    seaford
    thanks i'll give that a go.
    squirrelciv Guest
    Give David Sliver a ring on 01728 833020
    Best Honda spares guy I know, never let me down and usually has most parts in stock. If you give him an engine No, he'll do the rest, but I usually only have to give the model number.
    Best of luck
    Jul 2006
    seaford
    david silver is the place for bits ,turns out i've got an 91 not 92 and that the cable changed for the 92 dominator none of the other shops knew this and said that there was only one cable for the whole range so thanks !
  1. Clutch Cable
    By SteveLee in forum Africa Twin
    Last Post: 07-09-07, 08:38 AM
  2. Clutch cable lubing
    Last Post: 28-11-06, 03:45 PM
  3. Clutch cable question
    By barftone in forum Africa Twin
    Last Post: 04-11-06, 12:15 AM
  4. Clutch Cable!
    By Simon in forum Chatter
    Last Post: 18-05-06, 11:24 AM
  5. Clutch Cable
    By Paul P in forum Africa Twin
    Last Post: 25-02-06, 08:28 PM
