Results 1 to 4 of 4
Thread: Front brake noise
    jollyrodger2005 is offline Junior Member
    Mar 2006
    Front brake noise
    My front brake is making a wierd sound...like honing sound..checked the pads (only half worn ) and then thought the disc is rubbing on the side of the caliper...only happens when the disc is hot and just short of coming to a stop...got me stuffed what it is.
    anton88's Avatar
    Hi, If you cant see anything rubbing on the caliper/pads, try and get the front wheel up in the air so you can spin it round and feel any resistance.
    Could also be bearings - whilst wheel is up check for any play in the front wheel.
    if the bearings seem ok, and nothing visible on pads/disk, then i suggest a front caliper strip down and re-build - and new brake fluid. it could be that your piston is sticking, and the pads arent going back in - so when your disk gets hot, it expands a bit and rubs on the pads.
    Hope this helps, let us know how u get on.
    Rubberchicken's Avatar
    Amsterdam
    And if you're in there, don't forget to clean and lube those slider pins... Those are infamous for running dry and thus not-sliding and keeping pressure on the disc...
    Michel
    '89 NX650 -- R.I.P. -- Gone
    Mar 2006
    Thanks guys...l'll check out all that you said today and let you know
  1. Front Brake caliper
    By mal in forum Africa Twin
    Last Post: 01-04-09, 02:10 PM
  2. FRONT BRAKE LUNGING
    By collumbell in forum Africa Twin
    Last Post: 31-10-06, 01:21 PM
  3. re : Front brake upgrade
    Last Post: 27-05-06, 08:14 PM
  4. Front brake stuck
    By raymo in forum Africa Twin
    Last Post: 11-04-06, 11:39 AM
  5. Front Brake Calipers
    Last Post: 28-06-05, 06:31 PM
