No filings but chips in the engine ^ ^ - Page 5
Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 41 to 50 of 59
Thread: No filings but chips in the engine ^ ^
  1. #41
    650 Fred's Avatar
    650 Fred is offline Senior Member
    South wales
    Re: No filings but chips in the engine ^ ^
    Quote Originally Posted by Hondada View Post
    Brought the head to a shop to have the valves and seat rectified (is it the good word for that?)
    Cleaning crankcases and very hard old gaskets, I had to put them in hot water 5min. trying to soften them, but it's still quite hard without scratching the crankcases.
    What's the easy way to take the old gaskets away?
    I use a new wood chisel to remove gasket material but you have to use it the right way or it will dig in try it first before you go mad with it
    Current toys
    1993 CB1000 (Big one)
    1994 RD07
    1996 Modified NX650
    2001 XR400
    2016 CRF 1000L
  2. The Following User Says Thank You to 650 Fred For This Useful Post:
    Hondada (23-03-17)
  3. Remove Advertisements
    Hondada is offline Member
    Jan 2017
    France
    Quote Originally Posted by Mototed View Post
    Whats the code on the plug i mean..
    The standard plug has a M12 x 1.25 thread.
    Can't find the spark plug anymore... Believe it was worn when I took it off and threw it away.
  5. #43
    Jan 2017
    France
    Quote Originally Posted by 650 Fred View Post
    I also tried the end of a tooth brush that I sharpened, not bad.
  6. Remove Advertisements
    Bounder is offline Senior Member
    Feb 2011
    West Cork, Ireland
    You can buy spray cans of gasket remover, just spray it on and leave to work for a few minutes and then scrape away the softened gasket.
    If there is some still remaining then repeat.
    Wurth do a very good one called Décapant.
    Be very careful using steel scrapers on thin and soft alloy cases, its easy to slip and damage the surface and end up with a leak.
  8. The Following User Says Thank You to Bounder For This Useful Post:
    Hondada (23-03-17)
  9. #45
    Jan 2017
    France
    Engine cases are closed, but there is still a 1mm play on the primary shaft. Like I have no washers left on my bench, I'm wondering if it's normal? Would it be fixed with the clutch on?
    Name:  1mm side play 1.jpg
    Name:  1mm side play   2.jpg
  10. #46
    Jan 2017
    France
    Well, thanks to you all, engine is back in the frame. BUT no oil is coming at the head... I pushed the starter button more than 3 minutes, in several times of course, tried with an air gun to put the frame tank under pressure. Oil filter is full of oil. Thanks for your help.
  11. #47
    Mototed is offline Senior Member
    Nov 2015
    Wirral -UK
    Did you take the pump apart ?
    Did you prime the pump with oil ?
    Loosen the banjo bolt above the oil filter to check for oil flow.
    Sent from my G7-L01 using Tapatalk
  12. #48
    Jan 2017
    France
    Yes I took the oil pump apart. I built the oil pump in a pan full of oil, so I believe it's full of oil, but I didn't really prime it like making it turn with some oil getting through. The banjo is loosen on the cylinder head, and still waiting to see some flow out from there.
  13. #49
    Nov 2015
    Wirral -UK
    You need to prime it before fitting it. As per the manual..You most likely have an airlock. You might get lucky and it will eventually clear with plenty of compressed air and lots of cranking... But i hope your cams are oiled up if you're going to be doing that.
    Or you have assembled the oil pump incorrectly..
  14. #50
    Turbinerepair's Avatar
    Turbinerepair is offline Senior Member
    Dec 2016
    Netherlands
    I also took my pump apart during the rebuild of my AT, I forgot to prime it but I was lucky as after a short while of crancking the low oil press light went off and I had oil coming to the heads. As I understand it from googling (so probably not the most reliable source), priming is not really nessecary most of the times. Are you sure you rebuild it correctly?
  1. Stone chips at side of road
    By lowflyer in forum Riding
    Last Post: 24-10-08, 08:24 PM
  2. Cheap as chips GPS
    By Gnasher in forum Mechanical Advice
    Last Post: 06-03-08, 11:58 PM
  3. In Marrakech also eating chips.
    By xrewen in forum Travel
    Last Post: 22-02-08, 09:38 PM
  4. Touch up paint chips - HOW TO???
    By LUNLUNZAI in forum Mechanical Advice
    Last Post: 17-02-08, 09:59 PM
  5. Kettle Chips.....Mango Chilli flavour
    By Tarka in forum Chatter
    Last Post: 09-02-07, 05:54 PM
