Oil consumption Honda Dominator
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Oil consumption Honda Dominator
    Josko is offline Junior Member
    Dec 2016
    Split,Croatia
    Oil consumption on my Honda Dominator
    Hello there folks! Great forum you've got here.
    Newbie here, Joško from Croatia and i have a question about my 1998. rd 08 Dommie.
    Recently i've changed the oil after the 3000 km interval and it really struck me to find that i've only draind 0.9l of oil from it.
    Can anyone tell me what's the normal oil consumption for this bike?
    The bike has about 72000 km on it. And im using Motul 5100 15w50
    Thanks in advance!!
    Bounder is offline Senior Member
    Feb 2011
    West Cork, Ireland
    Re: Oil consumption on my Honda Dominator
    Which drain bolt did you use? there are two. One in the down tube between the headers just before it splits into the bottom double cradle.
    and one on the LHS of the engine just behind the gearchange lever.
    These engines will tend to use a lot of oil if run at high speeds >100kph for long periods of time.
    JamieB76's Avatar
    JamieB76 is offline Senior Member
    Jan 2015
    Sidcup Kent
    The longer I hang around the more use I become
    Here is the frame drain and then the bottom mesh filter position. I am about to do a post about this mesh filter in a moment. I have only checked the mesh twice since owning the bike.
    Here is the engine drain plug
    Honda NX650 1996 - Daily commuter
  5. Remove Advertisements
    Dec 2016
    Split,Croatia
    Quote Originally Posted by Bounder View Post
    Yes i've drained both of them.
    The bike is my daily commuter. And i make a minimum of 50 km daily (just going to work and back),and yes, my traveling speed is about 100 or 110 km/h everyday. Could this be the reason for that kind of oil consumption?
  7. #5
    Dec 2016
    Split,Croatia
    Quote Originally Posted by Josko View Post
    Anybody?
  8. #6
    Feb 2011
    West Cork, Ireland
    Could be a number of things, Valve stem oil seals, easy enough fix. Worn rings not so cheap/easy.
  9. #7
    Bobn's Avatar
    Bobn is offline Senior Member
    Apr 2011
    Derbyshire
    More to the point, do you not check the oil level every ride?
    Leaving it until there's only 0.9l left, you were very lucky you didn't trash the engine.
    At the sort of mileage on your engine you can expect some oil consumption. It will be a combination of stem seals and ring wear. The ring wear will burn oil but also allow a little blow-by which may well be pumping oil out of the crankcases.
    If the bike starts easily, runs well, ticks over when hot and doesn't smoke then just keep running it - but for Pete's sake check your oil level - every ride!
    Current Fleet:
    1999 FX650
    2001 FX650
    2002 FX650
    2003 FX650
    1998 KE100
    Past rides: TTR600,XT600E, KLE500(*4),FX650(*7),SLR650(*4),DL650,KLE500,F650, G650X,XJ900,TDM850(*2),XJ600(*3),FJ1200(*2),GS750( *4),GS1000,Z1000,GSXR750(*4),R1100GS,R80,GT550,VX8 00,GT250,ETZ250,TS250,TS185,TS125,KE175,CB250RS,Z2 00,C90,ETZ125,TS350,FZS600(*3),FZR600(*3),FZ750,GS 550,Monkey125,T80,GP100,CD200,RD200,GN400,CX500 and many others I've forgotten
  10. The Following User Says Thank You to Bobn For This Useful Post:
    Josko (11-02-17)
  11. #8
    Dec 2016
    Split,Croatia
    Quote Originally Posted by Bobn View Post
    I dont quite understand this. What do you mean by saying "Ticks over when hot"? You mean "if it runs well when hot?" Or something else?
    Thx
  12. #9
    Feb 2011
    West Cork, Ireland
    Tick over is another way of saying idling.
    Ticking over = Idling.
  13. #10
    Dec 2016
    Split,Croatia
    Aha, i see,thanks. Btw, could you tell me how much slack shoud be on the drivechain? I've changed it yesterday,and i've adjusted the chain tension while the bike was on a central stand,so that it was adjusted to around 35mm of slack. But driving it seems like it's loose a little bit because when i'm riding it and when i twist or release the throttle i can feel the drive chan punching a little and it seems like it's pulled up above the 35mm..
  1. honda dominator help needed with oil bleeding
    By craig1990cc in forum Dominator / FMX
    Last Post: 21-02-13, 06:46 PM
  2. which way does the oil feed pipes go on honda dominator
    Last Post: 02-01-13, 07:20 PM
  3. Oil Consumption on a Dominator
    By Zardoz in forum Dominator / FMX
    Last Post: 15-03-12, 10:10 PM
  4. Oil consumption?
    By Jerry in forum Varadero
    Last Post: 08-06-11, 12:44 PM
  5. Oil consumption!
    By specific in forum Dominator / FMX
    Last Post: 07-06-07, 01:17 PM
