Nuts and bolt restoration - Trouble with rear brake pads. - Page 2
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Nuts and bolt restoration - Trouble with rear brake pads.
    650 Fred's Avatar
    650 Fred is offline Senior Member
    South wales
    Re: Nuts and bolt restoration - Trouble with rear brake pads.
    It will still work without the retainer i think it is there to stop the aluminium mounting bracket from getting worn by the end of the pads it doesn't actually hold them in place. any honda dealer should be able to get it, cost about £8 here
    Current toys
    1993 CB1000 (Big one)
    1994 RD07
    1996 Modified NX650
    2001 XR400
    2016 CRF 1000L
    StuffThomasDoes is offline Junior Member
    Mar 2017
    Denmark
    Quote Originally Posted by 650 Fred View Post
    It will still work without the retainer i think it is there to stop the aluminium mounting bracket from getting worn by the end of the pads it doesn't actually hold them in place. any honda dealer should be able to get it cost about £8 here
    I'm hoping it's a retainer issue as that seems very easy to fix, can't really figure what else it could be.
    Summer is rapidly getting closer and this bike needs to see the open road soon!
  4. #13
    Mar 2017
    Denmark
    Alright, so I went and did some more work on the bike today, and I can't see it being anything else than being the shim and retainer missing from the assembly which is causing this issue?
    https://drive.google.com/open?id=1u3...eDnx_m-xVdcHcw
  5. Remove Advertisements
    650 Fred's Avatar
    South wales
    Either that caliper isnt pushed pushed down all the way to its correct location or you have the wrong brake pads for that caliper what year is year bike and is that the Nisin caliper you can see from my photo the pads stick out past the caliper unlike yours
    The caliper on mine looks allot closer to the mounting bracket than yours which is what makes me think yours is not all the way down could just be the angle of the video though
    Current toys
    1994 RD07
    1996 Modified NX650
    2001 XR400
    2016 CRF 1000L
  7. #15
    Mar 2017
    Denmark
    Fred you are a godsend!
    In my (terrible) video the caliper wasn't completely bolted down, however the issue remains when it is.
    Looking at your pictures it's clear to me that I have received the wrong brake pads. Mine are way too short compared to yours and no shim or retainer clip will fix that. Quick fix!
  8. #16
    Mar 2017
    Denmark
    Turns out you were right all along Fred!
    A new set of brake pads fixed it. Thanks alot, now on to the wiring....
  9. #17
    650 Fred's Avatar
    South wales
    Great thanks for letting us know you sorted it
    Current toys
    1994 RD07
    1996 Modified NX650
    2001 XR400
    2016 CRF 1000L
  1. Rear Brake pads
    By 650 Fred in forum Dominator / FMX
    Last Post: 05-04-15, 02:47 PM
  2. Rear Brake pads?
    By chunkolini in forum Africa Twin
    Last Post: 24-01-14, 06:35 PM
  3. Replies: 11
    Last Post: 21-12-13, 11:29 AM
  4. Buggered rear brake bolt
    Last Post: 17-11-13, 08:56 AM
  5. Rear Brake Pads
    By DaveS in forum XR
    Last Post: 09-07-07, 09:13 PM
