Pillion foot peg rubbers
Results 1 to 10 of 11
Thread: Pillion foot peg rubbers
    Fitz is offline Senior Member
    Mar 2013
    London, UK
    Pillion foot peg rubbers on my Dommie are perishing and falling apart, currently held on with cable ties.
    Despite the fact I NEVER take a pillion, this has been bugging me so I bought new ones from David Silver.
    Does anyone have experience/ top tips for replacing those? It looks like it would be a struggle to push them on from the "open" end of the peg due to the prominent metal lip which helps keep them on. It looks like it would be better to dismantle the peg and push the rubbers on from the pivot end. But I have not tried dismantling a foot peg before, so what do I know?
    Thanks in advance for any advice.
    Sent from my iPhone using Tapatalk
    2000 W-Reg RD08 Dommie - my commuter bike!
    2014 Honda VFR800 F-E - Sunday best
    Bounder is offline Senior Member
    Feb 2011
    West Cork, Ireland
    Re: Pillion foot peg rubbers
    The pegs are held on by a pin with a split pin and washer on the bottom.
    They are easily removed just pull the split pin and remove the washer and pin and the peg will come off.
    Cut the old rubber off and use some hairspray on the inside of the rubber and then slide the new rubber on to the metal and adjust to fit.
    Mar 2013
    London, UK
    Thanks Bounder, sounds easy enough (famous last words...)
  5. Remove Advertisements
    Feb 2011
    West Cork, Ireland
    I have seen people using cable ties to help the rubber slide on and then removing the cable ties once in place as well.
    Good luck with it.
  7. The Following User Says Thank You to Bounder For This Useful Post:
    Fitz (21-03-17)
  8. #5
    Mar 2013
    London, UK
    Got one off the pegs off, replaced the rubber, cleanup and reassemble no problem. The other one needs a new pin and a new split pin for reassembly.
  9. #6
    Feb 2011
    West Cork, Ireland
    Great was the other pin flogged out or just rusty?
  10. #7
    Mar 2013
    London, UK
    The split pin snapped off inside but the footpeg pin itself was well worn so probably worth replacing anyway.
  11. #8
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    What size is the pin I have some stainless ones at home. Cannot remember the size at the moment. But they have stainless washers and split pins with them .
    Sent from Tapatalk
    Classic Japbikefest 2 http://www.vjmc.com/japbikefest/ Sunday 14th september 2014 10am haynes motor museum
  12. #9
    Feb 2011
    West Cork, Ireland
    The trick for the rubbers is to have them pushing on the plate between the rubber and the end of the footrest, this helps to stop them rattling and wearing the pin.
  13. #10
    Mar 2013
    London, UK
    Quote Originally Posted by Mervinh View Post
    Sent from Tapatalk
    Thanks, I'll measure when I get home and report back.
  1. Replacement pillion peg RD04
    By chunkolini in forum Africa Twin
    Last Post: 11-09-15, 02:43 PM
  2. Wanted: Right Front Master Cylinder+R-Pillion Foot Peg for RD07
    By misterjames in forum For Sale / Wanted
    Last Post: 24-05-14, 12:39 PM
  3. AT Right Pillion Foot Peg?
    By misterjames in forum Africa Twin
    Last Post: 10-01-14, 03:57 PM
  4. Wanted: RD04 Right Hand Pillion Peg Hanger
    By kitped in forum For Sale / Wanted
    Last Post: 06-06-10, 07:43 PM
  5. Pillion peg fracture and rear protection..
    By StormRider in forum Varadero
    Last Post: 31-01-09, 07:16 AM
