Oil cooler
Results 1 to 10 of 10
Thread: Oil cooler
    scouseviking is offline Senior Member
    Feb 2013
    Denmark
    Oil cooler
    This time last year I asked about fitting an oil cooler on my Dommie but got side tracked as I was having clutch and flatside issues and lack of funds to finance an oil cooler.
    Anyhoo ,the clutch was replaced and now works as it should and my flatside is dialled in now with the help of our resident scrambling flatside guru from brummingham.
    I managed to stash some cash over the winter and now my Dommie is ready to have me thrash the bejeezuz out of it I thought it might be a good idea to hook up an oil cooler...
    I dont want to get one stateside as the VAT and import duty will make it un-affordable...
    Any suggestions about fitting an oil cooler and where to source the parts from?
    Are there any craftsmen left in blighty that can fabricate this kinda thing or do I have to spend my money elswhere?
    whoisdc's Avatar
    whoisdc is offline call me Dave
    Jan 2011
    south of theblack stump between portsmouth and southampton on the coast
    Re: Oil cooler
    I have two dommies with oil coolers on them .
    i plumb them in for the summer then replum in the winter .This takes about 10 minutes tops as all i do is replace the rubber oil feed connections.
    The first is a wrap round headstock type, if you look on the thumper forum you can see the link ,i will post some pics later of mine.
    The second is from a Toyotoa car positioned on the frame down tube in full air flow position.
    they work well . Ihave seen lots of different types of oil coolers ,the ones from the states(and germany ) are all very chic and fit where the toolbox sits. remember to fully charge the oil feed pipes and the cooler prior to starting the machine.
    I have had no issues with this cheap modhttp://s1043.photobucket.com/user/whoisdc20/libraryhttp://s1043.photobucket.com/user/whoisdc20/library//http://s1043.photobucket.com/user/whoisdc20/library/
    nick in brum is offline Senior Member
    Dec 2010
    in my shed in birmingham
    Re: Oil cooler
    Do you really think you need one ?
    The reading on my temp dipstick rarely gets above 100 and this is with a high compression big bore piston which creates more heat than a stock set up, the red zone on the thermometer is 120,
    The dipstick reading is the hot oil returning to the oil tank, once its passed through the frame down tube it will have cooled a few degrees
    xjr1300,gs1000,nx650 scrambler,triumph 500,dr350,
  5. Remove Advertisements
    Feb 2013
    Denmark
    Re: Oil cooler
    Quote Originally Posted by nick in brum View Post
    I think before I splash out ,I should get one of those thermometer dipsticks and see how it the temp goes.
    My vaportec fidgital speedo has a temp sensor which I fitted to the head but its got so many flashing lights and numbers I dont bother with it..
    Are those temp dipsticks accurate and are the ones on ebay any good?
  7. #5
    Bounder is offline Senior Member
    Feb 2011
    West Cork, Ireland
    Re: Oil cooler
    The dipstick thermometers are good but the RR ones made in Germany are better than the cheap knockoffs, I have heard that the plastic clouds over after a while with the cheap ones.
    Louis sell the RR ones for 65
    https://www.louis.ie/artikel/rr-oil-...list=277932365
  8. The Following User Says Thank You to Bounder For This Useful Post:
    scouseviking (02-05-17)
  9. #6
    Dec 2010
    Re: Oil cooler
    Quote Originally Posted by scouseviking View Post
    Hard to say how accurate they are, dont know how i could test it, but it is a good indicator , if it usually runs at 90-100 degrees and then starts reading 120 you know somethings not right,
    i got mine off ebay made by JMP , so far so good about 18 months, its only a thermometer a fairly simple device not much to go wrong with it i wouldn't think
  10. #7
    lepews's Avatar
    lepews is offline Junior Member
    Dec 2016
    Fremantle, Western Australia
    Re: Oil cooler
    Mine came with the bike, looks good and no troubles so far. Usually runs near 100C once properly hot.
    I'm guessing a good way to test it would be to make a cup of tea - once the kettle boils drop the oil gauge in and it should read pretty close to 100 degrees!
  11. #8
    Feb 2013
    Denmark
    Re: Oil cooler
    Quote Originally Posted by lepews View Post
    How does the tea taste once you dipped your stick in it?
  12. #9
    650 Fred's Avatar
    650 Fred is offline Senior Member
    South wales
    Re: Oil cooler
    Their not too far out mine reads about 5 deg C too high its the cheap one and been on the bike for about 4 years no issues and still using the original O ring, As for the oil cooler here in the UK i dont think theres any need for one i had fitted the one off XR400 a few years ago but had to remove it to fit the big tank as the hot oil pipes were touching the plastic tank. can't say i noticed any difference in the running temperature afterwards. I have noticed it runs a bit cooler after changing the carb and having it set up properly
    That's just under 80 Deg C on the dipstick
    Current toys
    1993 CB1000 (Big one)
    1994 RD07
    1996 Modified NX650
    2001 XR400
    2016 CRF 1000L
  13. The Following User Says Thank You to 650 Fred For This Useful Post:
    apox (03-05-17)
  14. #10
    Bobn's Avatar
    Bobn is offline Senior Member
    Apr 2011
    Derbyshire
    Re: Oil cooler
    Got them on all mine. Check the accuracy in a pan of boiling water, I checked one and it pretty good - within 3 or 4 degrees.
    In my experience the hottest temperatures are seen on the motorway, off-road usually cools them down a little bit.
    Normal running in 15C ambient is ~ 95 or 100C
    In summer on a hot day I can see 115C, if it goes above I throttle back and let it cool down.
    I can see how a Dommie with it's higher power O/P could cook itself if ridden hard for long periods in a hot climate.
    Current Fleet:
    1999 FX650 Red
    1999 FX650 Blue
    2001 FX650 Yellow
    2002 FX650 Blue
    2003 FX650 Yellow
    2003 FX650 Yellow
    1998 KE100
    Past rides: TTR600,XT600E, KLE500(*4),FX650(*7),SLR650(*4),DL650,KLE500,F650, G650X,XJ900,TDM850(*2),XJ600(*3),FJ1200(*2),GS750( *4),GS1000,Z1000,GSXR750(*4),R1100GS,R80,GT550,VX8 00,GT250,ETZ250,TS250,TS185,TS125,KE175,CB250RS,Z2 00,C90,ETZ125,TS350,FZS600(*3),FZR600(*3),FZ750,GS 550,Monkey125,T80,GP100,CD200,RD200,GN400,CX500 and many others I've forgotten
  15. The Following User Says Thank You to Bobn For This Useful Post:
    scouseviking (19-05-17)
  1. Replies: 0
    Last Post: 20-06-14, 08:41 PM
  2. Oil Leak - Oil cooler pipes?
    By philsmith in forum Africa Twin
    Last Post: 01-07-13, 01:06 PM
  3. Oil cooler
    By Underground in forum Dominator / FMX
    Last Post: 21-03-12, 11:19 PM
  4. Oil Cooler
    By Richard Ludwell in forum Dominator / FMX
    Last Post: 24-06-08, 07:14 PM
  5. Oil Cooler on TA
    By Gromit3528 in forum Transalp
    Last Post: 05-09-07, 02:16 PM
