Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: Cant get the front axle out !
    Mar 2006
    Sidcup, Kent
    Hey everyone.
    My speedo has given up.
    Checked the cable seems fine.
    I removed it from the clocks and rode up and down the road but the inner 'bit' wasn't turning.
    I removed (eventually) the securing screw at the wheel hub on the speedo pickup gear and with the front wheel off the ground spun the wheel, the inner 'bit' of the speedo gear wasn't turning
    I decided to remove the lot and inspect, however I cannot get the flippin' axle out, no matter how much I huff and puff. It's all back together now, while I figure out how I am going to remove it.
    Any ideas ?
    Rubberchicken's Avatar
    Amsterdam
    Re: Cant get the front axle out !
    You did know the axle screws into the left fork leg, right?
    Michel
    '89 NX650 -- R.I.P. -- Gone
    Richard Ludwell is offline Junior Member
    Ware. Hertfordshire. UK
    Quote Originally Posted by Scott View Post
    Hey everyone.
    Any ideas ?
    You have loosened off the four 6mm nuts on the bottom right hand fork leg which locks the axle & then unscrewed the axle which is threaded into the bottom of left fork leg as Rubberchicken has mentioned.
    Cheers Richard Ludwell.
    Confucious's Avatar
    Confucious is offline Senior Member
    Norway
    Quote Originally Posted by Richard Ludwell View Post
    .....and take it easy when you reinstall them...I've already sheared one ....I think they are 12nM - but dooooo check !
    Mar 2006
    Sidcup, Kent
    Doh !!
    OMG...I didn't know it "screws" in/out. I was even using the Honda manual and didn't notice that bit
    Thank you everyone....I'll just slink off to the garage and hang my head in shame............
    Doh !!
    Don't worry Scott we've all been in the sh t at some time, & as Confucious says be very carefull about the tightening up, yes it is 12nm. Cheers Richard
    Amsterdam
    12 Nm -- Which is very fookin little indeed. Beware.
    And yeah I know the feeling, had the reverse feeling with the GS recently, shortly.
    Axle, spin spin spin spin spin fsck me is the thread buggered or what? Oh it just pulls out, heh.
    Michel
    Mar 2006
    Sidcup, Kent
    LOL
    OK. I have discovered the fault. The little plastic gear in the speedo hub is broken.
    Take a look at the pictures
    I bet no one sells them, I bet I've got to get the whole bloomin' hub.
    I'm gonna try WEMOTO and Honda....Honda should keep it, I hope.
    Thanks again guys.
    Amsterdam
    They do. Nr 15 in the pic (bit hard to see, next to the 2x 16)
    Part nr is 44806-KF0-000
    Michel
    Hi Scott, I think Rubberchicken is right because I am looking up the same type of speedo drive for a CBR600FH (1987) & the Honda parts book for that bike list the complete speedo drive & the individual parts, so have a crack at David Silver Honda spares tel no: 01728 833020.
    Cheers Richard.
  1. Pesky axle clamp bolts!
    By Slimjim in forum Transalp
    Last Post: 21-06-07, 08:59 PM
  2. Visible front axle length
    Last Post: 20-03-06, 06:01 AM
