Results 1 to 8 of 8
Thread: electrical help
    rikki1q is offline Member
    Sheffield south yorkshire
    electrical help
    i have finally found the right panel i need to get the dommie back on the road and i have sorted out the ignition but next to the indicator wire on the right side there is another wire hanging down and i dont know where its from any ideas?
    Mar 2006
    Sidcup, Kent
    Re: electrical help
    Got any pictures ?
    Stick one on here and I'll compare to mine.
    Re: electrical help
    http://www.xrv.org.uk/photopost/show...04/ppuser/2650
    next to the fork leg there is a conector that spurs off the indicator wire and i have no clue where it goes to and i suspect i may be why my indicators dont work
    Re: electrical help
    the rpoblem seems to be not only are the indicators not coming on the warning lights on the dash panel are not coming on either indicating the turn signal is active the other lights etc work fine so i suspect this wire is something to do with the indicator relays i really could do with some help on this one guys i wanna get me bike back on the road asap
    cheers
    jimirobinson is offline Junior Member
    Bournemouth UK
    Re: electrical help
    I can't really see from your photos. Possibly close up and a description of the connections (colours etc.) might help.
    On the right hand side the loom goes to the osf indicator, the cdi and the flasher relay. Eliminate them from that.
    In my experience if none are working it's the relay.
    Re: electrical help
    http://www.xrv.org.uk/photopost/show...o/1547/ppuser/
    in the above pic i have circled 3 things number 1 is a bracket that seems to be rather empty is anything missing from it? flasher relay perhaps
    number 2 is the mystery wire that i am stumped about
    and number 3 is the indicator wire
    as always any help for this dumbass is helpful
    cheers guys
    Bournemouth UK
    Re: electrical help
    Yep, Your flasher relay is missing
    Re: electrical help
    brilliant now i know whats missing i can get a new one from wemoto i dont fancy trying to ride doing hand signals hehehe drivers are blind enough already without having any indicators cheers for the help
  1. Electrical failure ???
    By old red eyes in forum Africa Twin
    Last Post: 18-02-07, 06:51 PM
  2. Electrical Connections
    By DaveS in forum Chatter
    Last Post: 28-09-05, 10:14 PM
  3. Help, electrical problem
    By clbuff in forum Africa Twin
    Last Post: 02-08-05, 10:04 AM
  4. 12v Electrical Sockets
    By XRV_AndyM in forum Africa Twin
    Last Post: 28-07-05, 10:28 PM
  5. HELP...ANOTHER ELECTRICAL PROBLEM
    By SHARPY in forum Africa Twin
    Last Post: 31-05-05, 04:10 PM
