Results 1 to 5 of 5
Thread: domi hunting judder under 3000rpm
    kevin nx650 is offline Junior Member
    Jun 2007
    norfolk
    Hi people. I own a 1991 NX650/dominator which had been rebuilt with piston,rebore valve rockers, timing chain, rocker guides and clutch.
    it runs good except when in 3rd,4th or 5th and engine speed under under 3000rpm it hunts/judders, the engine seems firm in the frame, chain and sprocket are ok and no loose bolts. above 3k no problems, has anyone any ideas or areas to check.
    Thanks Kevin
    anton88's Avatar
    Re: domi hunting judder under 3000rpm
    Hi Kevin,
    you may find that the dommie doesnt like running in those gears below 3000 rpm - i know mine can be a bit lumpy at those revs/gears - or did the bike run fine at thes settings before the re-build ?
    Jacqueslemac's Avatar
    Jacqueslemac is offline Top Cat
    Norfolk and Normandy
    Mine too. I think it's just one of the downsides of a big single.
    Rubberchicken's Avatar
    Amsterdam
    Check if the shift lever moves down.
    Michel
    '89 NX650 -- R.I.P. -- Gone
    churches67 is offline Member
    Mar 2007
    RYDE I.O.W
    Mine did same ,juddering in 4th ,5th found problem to be the rear sprocket bearing had broken up,£5.99 from Wemco problem sorted.
    Ian.
  1. Domi Newbie
    By rikki1q in forum Dominator / FMX
    Last Post: 20-01-07, 04:00 PM
  2. Varadero Hunting!!
    By z-weiser in forum Varadero
    Last Post: 29-12-06, 09:13 PM
  3. Domi died on me??? : - (
    By The Cosmic Lawnmower in forum Dominator / FMX
    Last Post: 21-06-06, 10:54 PM
  4. Who said that Domi was not amphibian ???
    By lreal in forum Ride Reports and Pictures
    Last Post: 18-05-06, 08:54 AM
  5. Carb for 97 Domi
    By Frayed Dave in forum Dominator / FMX
    Last Post: 02-05-06, 07:41 PM
