Results 1 to 10 of 11
Thread: Gear Lever - new one ?
    Keef's Avatar
    Keef is offline Member
    Apr 2007
    Sydney
    Hi
    My gear lever was very loose when I bought my Dommi. I made some mods to it so that it would tighten up and it has been good for about 4000kms.
    Now it's getting loose again , just wondering if anyone has had cause to replace the gear lever ? Any suggestions?
    The Shaft seems to be in good condition , I think the lever is just worn from being used while loose.
    Rubberchicken's Avatar
    Amsterdam
    Re: Gear Lever - new one ?
    I'm on my 3rd or 4th I think...
    They do tend to come loose, and if you're not careful they will stuff up both the splines on the lever and the shaft.
    Michel
    '89 NX650 -- R.I.P. -- Gone
    Keef's Avatar
    Apr 2007
    Sydney
    Ah OK , I'll stop being cheap and get a new one
    Amsterdam
    Indeed. They're a bit dear.
    Michel
    kenny1950's Avatar
    kenny1950 is offline Senior Member
    Oct 2006
    Spalding Lincolnshire England
    Try drilling out the threads and put a high tensile bolt right through. Also remove a little of the gap where it nips together. I managed to salvage a worn spline and its still tight after 2 years.
    Ken
    Quote Originally Posted by Keef View Post
    Hi
    Amsterdam
    Quote Originally Posted by kenny1950 View Post
    Be careful with that though, the chain runs pretty close above the shifter.
    Michel
    Lam's Avatar
    Lam
    Lam is offline Senior Member
    Jul 2007
    Kerry Ireland
    Hi
    It does seem to b a weak point wit Dommies and you need to check regularly.I,m on my 3rd lever,I totally destroyed a brand new one from David Silvers a couple of months back when I needed to jam on and go down the gears
    You say shaft is ok,so new lever should be grand.
    If the shaft was damaged you could put a bolt into the shaft/lever.I,ve done this and the thing won,t budge.Need to b steady with a drill etc etc.
    Will try to post a pic tomorrow,easier to view than put in words
    Keef's Avatar
    Apr 2007
    Sydney
    Thansk guys , I will get a new one.
    I have removed some material from where it pinches together before and that worked as I could tighten it up.
    But it's started to come loose again.
    beertastic is offline Member
    Nov 2006
    London, UK
    I've got a spares/repairs '89 dommie in central London if you need a part...
    Keef's Avatar
    Apr 2007
    Sydney
    Quote Originally Posted by beertastic View Post
    Thanks for the offer but I'm a little bit south of you here in Sydney Australia
    I asked my local bike shop , a honda gear lever will cost me $60, I'll hunt around and find a cheaper after market one.
  1. Retactable gear lever - TA 650
    By default in forum Transalp
    Last Post: 01-05-07, 01:19 PM
  2. Clutch Lever
    By Keef in forum Dominator / FMX
    Last Post: 01-04-07, 08:24 AM
  3. wires on clutch lever
    By churches67 in forum Dominator / FMX
    Last Post: 25-03-07, 09:44 PM
  4. Front brake is very notchy at the lever end
    Last Post: 16-06-06, 04:29 PM
  5. 650 brake lever question
    By nellychat in forum Africa Twin
    Last Post: 03-02-06, 01:19 PM
