Results 1 to 4 of 4
Thread: FMX650 wheels into Dommie, help.
    bob.106 is offline Junior Member
    Jul 2007
    shrewsbury
    Red face FMX650 wheels into Dommie, help.
    Hello folks Im new to your forum and would apprieciate your help, Does anyone know if FMX650 supermoto wheels will drop straight into my 1992 dommie or do I need to make a few conversions to the fitting, Im no stranger to the spanner or big thumpers but dont want to spend big cash if there is big complications, Many Thanks for your help. Bob.
    shuriken's Avatar
    shuriken is offline Senior Member
    May 2007
    Southsea. UK
    Re: FMX650 wheels into Dommie, help.
    Was thinking the same thing. Saw some on ebay and got me thinking. The bike is pretty much the same as ours, though less powerful and the frame is the same as is the rear swinging arm from the looks of it. I'd say the rear wheel will fit but you'd need to see if the front spindle is the same diameter. The rear end looks identical to our Dommies just a wider rim.
    Rubberchicken's Avatar
    Amsterdam
    The frame is not the same actually.
    The FMX frame might be the same as the SLR and Vigor (not sure) but definitely different from the NX.
    (No clue about the wheels fitting or not)
    Michel
    '89 NX650 -- R.I.P. -- Gone
    shuriken's Avatar
    May 2007
    Southsea. UK
    As the engine is almost the same, I kinda meant that the frame "was the same", not identical if you get my meaning. As the engine is the same width and the mounting points must be nearly the same I took it that the swing arm would be the same width, at mounting. Swing arm looks very similar too, check part numbers for spindles of both bikes and see if the same part, or measure the thread of FMX spindle toget an idea. I'd bet that rear wheel would fit, if I had the money I'd have bought the FMX wheels off ebay.
    I take your point Rubberchicken, so stand to be corrected.
  1. FMX650?
    Last Post: 15-11-09, 09:06 PM
  2. New Member & FMX650 Owner
    By scudmotodude in forum Dominator / FMX
    Last Post: 25-03-08, 12:51 PM
  3. Dommie wheels on an AT?
    By GeoBloke in forum Africa Twin
    Last Post: 22-06-07, 04:58 PM
  4. Dommie or TA? A wierd one...
    By Warthog in forum Mechanical Advice
    Last Post: 01-04-07, 09:39 PM
  5. The Adventure FMX650!
    By LaughingBob in forum Chatter
    Last Post: 29-10-05, 11:56 PM
