Results 1 to 7 of 7
Thread: Dead Dommie
    squirrelciv Guest
    Unhappy Dead Dommie
    Left work this afternoon as usual. Bike started first push of the button, pulled of and travelled 200yrds when the old girl stalled at a roundabout then.......
    .......nothing! Bugger all, nowt, zilch, nothing. No power, no lights, no starter, nothing.
    Pushed back to the yard, and whipped off the side cover to check main fuse only to find everything OK, so decided to call out the AA. The man arrives and puts a meter over the battery as I laugh saying "Won't be that mate, when I pulled off I had enough juice to spin the motor no probs" Meter showed under 2v coming out the battery (some ketchup with my humble pie please waiter)
    Bike would start off a jump lead and run once the leads were removed, and shows 13v across the battery, but switch off and the voltage plummets instantly to less than 2v.
    So it would appear that my battery has gone open circuit straight after pulling off from work so it's off to Thunder road motorcycles in the morning to part with £40
    Before I do, anyone else got any other ideas?? Alternators producing juice alright and the regulators seems to be keeping it steady (as far as I can tell with a duff battery still in the circuit) so I can only conclude a knackered battery. It is the original item of about 12 years of age.
    HUDDERS's Avatar
    HUDDERS is offline Shorter member :-)
    Apr 2007
    Barnoldswick, Lancashire
    Re: Dead Dommie
    Could you not make a new battery be for morning
    Rubberchicken's Avatar
    Amsterdam
    Re: Dead Dommie
    12 years isn't bad...
    Mine went *phut* sometime during the winter of 2005 (we actually had snow then!) and that wasn't even the original battery but a fancy Varta.
    You didn't even try to bumpstart it?
    Michel
    '89 NX650 -- R.I.P. -- Gone
    squirrelciv Guest
    Re: Dead Dommie
    Are you kidding!
    To be honest when she conked out I assumed I'd blown the main power fuse and thought nothing would start her. Never had a battery fail sooooo suddenly before, they usually fade off.
    Amsterdam
    Re: Dead Dommie
    Ofcourse I'm kidding.
    A couple of months ago I had some wiring problem acting up, resulting in the starter relay mostly not working. And my dommie doesn't have a kickstarter...
    So there I was, in the rain, on the wet cobblestones of Dam Square. Chances of getting a big single bumpstarted? Absolutely effing zero.
    It finally started though, lucky me.
    Michel
    Sharribee's Avatar
    Sharribee is offline Matron
    Jan 2006
    Wales
    Re: Dead Dommie
    Patrick if you are still having problems PM me, Jason is really good with fixing stuff so may be able to help
    DELILAH
    2010 F800 GS
    squirrelciv Guest
    Re: Dead Dommie
    Quote Originally Posted by Sharribee View Post
    Thanks for that Mabe, but a new battery was all that was required Fitted and running in an hour, didn't like the £35 bill though
  1. Dead Dog......
    By doglegdon in forum Chatter
    Last Post: 15-07-07, 10:35 AM
  2. Its dead !!!
    Last Post: 08-01-07, 02:51 PM
  3. Dead AT :(
    Last Post: 24-04-06, 01:53 PM
  4. Dead icu
    By cabbage2404 in forum Africa Twin
    Last Post: 18-04-06, 09:36 AM
  5. Dead icu
    By cabbage2404 in forum Transalp
    Last Post: 16-04-06, 12:49 PM
