Bike cuts out while riding - Page 2
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Bike cuts out while riding
    Bobn's Avatar
    Bobn is offline Senior Member
    Apr 2011
    Derbyshire
    Re: Bike cuts out while riding
    BTW, a possible easy fix is to stick 1/2 litre of Isopropyl Alcohol in the tank at the next fill up. The IA mixes with water and will be burnt through the engine in the normal way. You can get IA from your local Pharmacy. It's also excellent for degreasing parts prior to gasket fitment.
    It's deadly poisonous by ingestion in case anybody was thinking of using it as a mixer....
    ianrg is offline Junior Member
    May 2011
    North lincolnshire
    Well the problem is still there after carb removal and refitting. Checked fuel tank breather - fine. Ran ok for about 20 miles and then just died without warning again. It starts up again no problem.
    I'm on the verge of ordering a new CDI unless anyone has any other ideas that could be worth trying first.?
  4. #13
    switch's Avatar
    Feb 2009
    Romania
    Check the impedance of the crank sensor - both cold and warm. I remember such a problem a while ago. Without proper crank input even a good CDI doesn't work.
  5. #14
    May 2011
    North lincolnshire
    Thanks to all who replied - have replaced the CDI unit and the bike is now running like a dream!
  1. Replies: 57
    Last Post: 13-06-07, 06:22 AM
  2. Replies: 10
    Last Post: 18-04-07, 08:40 PM
  3. speed limit cuts for nearly all country roads
    By icenian in forum Chatter
    Last Post: 04-09-06, 09:47 AM
  4. riding in the wet
    Last Post: 02-09-06, 10:14 PM
  5. Replies: 28
    Last Post: 01-01-70, 06:21 PM
