Results 1 to 10 of 14
Thread: Bike cuts out while riding
    roosterman is offline Junior Member
    Jun 2007
    Australia
    Gidday everyone,
    Just wondering if anyone has encountered the same problem.
    I got a 93 model NX 650 Dominator and the bike would be cruising alone fine and then all of a sudden just cut out at any time.If I pull over to the side of the road it fires up first pop if I flogg the bike it cuts out again but if I just cruise along normal its fine till the next time it cuts out.
    Any help would be greatly appreciated as this is driving me nuts!!!
    Thanks in advance.
    Lam's Avatar
    Lam
    Lam is offline Senior Member
    Jul 2007
    Kerry Ireland
    Re: Bike cuts out while riding
    Hello there,
    click forums,then look in the Dommie section.There's plenty of post's about this.It's a common enough complaint
    here's 1 link,have a look
    http://www.xrv.org.uk/forums/showthr...4537#post20453
    best of luck
    ianrg is offline Junior Member
    May 2011
    North lincolnshire
    Hi
    Did you ever sort this problem out - I have an identical problem with my '92 Dominator.
    switch's Avatar
    Feb 2009
    Romania
    Sounds like a CDI, sidestand switch or engine kill switch issue, especially if it cuts out while under load. Start by tapping the CDI while idling. If it dies, you have the usual connector problem. Otherwise check switches first then check with a known-to-be-good CDI.
    May 2011
    North lincolnshire
    hi there thanks a lot for your info i shall start checking these out first thing
    Bobn's Avatar
    Bobn is offline Senior Member
    Apr 2011
    Derbyshire
    Sounds like the classic fuel tank breather blockage to me. No air into the fuel tank = no fuel out.
    Check your filler cap...
    Bounder is offline Member
    Feb 2011
    West Cork, Ireland
    Or possibly crap in the carb, full noise flows a lot of fuel sucking the object into the jet = cut out
    Once you stop, the object drops out and you can restart, taking it easy it doesn't get sucked into the main jet.
    Have you tried pulling the choke in when it cuts out or does it just die completely?
    I had this recently when I fitted a second hand carb to my 88 US model, there was a bit of old varnish or something blocked the main jet and I had to pull over and use the choke to limp home, there was a tiny bit of crap blocking the main jet.
    Bobn's Avatar
    Apr 2011
    Derbyshire
    Yes - I had a BMW F650 that used to do that when the carbs got a spot of water in them (which they often did due to the plasitc tank and condensation).
    May 2011
    North lincolnshire
    thanks for your tip i shall check it out
    May 2011
    North lincolnshire
    hi there i think you may have hit the nail right on the head thank you ill let you know how it goes ?
  1. Replies: 57
    Last Post: 13-06-07, 07:22 AM
  2. Replies: 10
    Last Post: 18-04-07, 09:40 PM
  3. speed limit cuts for nearly all country roads
    By icenian in forum Chatter
    Last Post: 04-09-06, 10:47 AM
  4. riding in the wet
    Last Post: 02-09-06, 11:14 PM
  5. Replies: 28
    Last Post: 01-01-70, 07:21 PM
