Results 1 to 8 of 8
Thread: Throttle return
    wayne.morris7 Guest
    Lightbulb Throttle return
    Just put back together my '91 NX650, after full strip & rebuild, however I can't seem to get the throttle cable routing right. took pictures and put them back where I found them, but the twist grip is very slow to return. All cables were cleaned & re-oiled & moved fine on the bench so I can only assume it's the routing. Anybody got any tips?
    kenny1950's Avatar
    kenny1950 is offline Senior Member
    Oct 2006
    Spalding Lincolnshire England
    Re: Throttle return
    Check you dont have the twistgrip pushed too far onto the handlebar. If you do the rubber end will rub on the handlebar and make a slow return. Also be sure the cables arnt to tight and fighting each other for slack
    ken
    Lumiya's Avatar
    Lumiya is online now The Dark One
    Ziost
    Re: Throttle return
    Is it a single or a double cable set-up. If double then try reducing the tension on each side of the cable as too much tension on one side can cause this effect.
    Kymmy
    wayne.morris7 Guest
    Re: Throttle return
    thanks Kenny1950, but grips are open ended - due to Acerbis handguard fittment, problem still there even when I removed this & could see the plastic
    wayne.morris7 Guest
    Re: Throttle return
    thanks Kymmy - it's a double arrangement, and yes I took out all the slack to manual specification, I'll try putting slack in it as you suggest
    Re: Throttle return
    Quote Originally Posted by wayne.morris7 View Post
    Try loosening the small screws that clamp the throttle assembly around the handlebar a little and see if the throttle starts snapping back more easily.
    I've had this on two Africa Twins now. I throw away the white nylon insert that the cables slide over and have a throttle that closes smartly at all times. I was worried the cables would fray when I first did it about 5 years ago, but my last bikes throttle cable was still fine after 130,000 miles (I oil them frequently) of which about 90,000 were with no insert.
    Gromit3528's Avatar
    Gromit3528 is offline Barking
    Apr 2007
    Northants
    Re: Throttle return
    I have found this on mine even with loads of slack in the cable, but in my case I found that when retightening the two screws (with the nylon guide in place) if you tighten the rear one fully (so the clamp is closed at the rear) and then tighten the front one................. the problem goes away
    wayne.morris7 Guest
    Re: Throttle return
    thanks - this weekend will see me try all the tips
    thanks to all who have replied
  1. PROJECT BLACK PEARL... MARMITES RETURN !
    By Chad in forum Other Bikes
    Last Post: 24-01-07, 08:11 PM
  2. Return from the wilderness.
    By old red eyes in forum Chatter
    Last Post: 22-09-06, 10:08 PM
  3. Throttle Take up
    By Shepp in forum Africa Twin
    Last Post: 28-05-06, 07:05 PM
  4. Return to idle
    Last Post: 19-10-04, 08:00 AM
  5. Return from the wilderness.
    By old red eyes in forum Africa Twin
    Last Post: 01-01-70, 05:00 PM
