Results 1 to 7 of 7
Thread: oils.........
    Tjokk is offline NX650 1989
    Australia
    oils.........
    Hi , I got an instruction manual on a cd rom . Good plan , but I cant find any specs about the engine oil . Viscosity .
    Also , transmission oils? Fill , drain ,,,,,,,,,,??
    Any suggestions (apart go to bike shop.....)
    Krtek's Avatar
    Krtek is offline They say I talk too much.
    Arnhem, the Netherlands
    Re: oils.........
    I think you'll need more than an instruction manual. If I were you I'd order an actual repair manual. Those things are so useful they'll pay for themselves.
    KirriePete's Avatar
    KirriePete is offline Senior Member
    Land of hills and heather
    Re: oils.........
    Oils - any decent 10W/40 API spec SE or better. If you go the semi-synth route make sure it's bike specific as car semi-synth has friction modifiers which can cause clutch slip (go on, ask me how I know!). Transmission shares the same oil as the engine which, at 2 litres a time, is why you should change every 1500-2000 miles.
    Oh, and remember there's 2 drain plugs, one in the crankcase just forward of the gear shift, the other at the bottom of the tank/downtube.
    Oh, and 2 screens, one by the clutch, one under the oil tank.
    Oh yeah, you can only put 1 litre or so in the tank when you refill, so you put half the oil in, run the engine then top up with the other half.
    If you're looking for a manual there's one available on-line here:
    Click Me
    Bottom of list on the left - click on Manual Download and there you go, section by section. OK so it's for the '91, but the differences are few and far between, it makes for a very good reference when attacking your bike with the spanners.
    You're welcome.
    Australia
    Re: oils.........
    Thanks heaps Kirriepete . I never heard of that one: "Engine and transmission sharing the same oil"
    Just to get back on the viscosity : Here in eastern Australia the weather is pretty warm (hot) .Specially in summer . Would it be a good idea to run the engine with 20W/50 API aa the bike is a bit old (1989) ?
    And........thanks for the advice!! Cheers
    KirriePete's Avatar
    Re: oils.........
    Quote Originally Posted by Tjokk View Post
    Just to get back on the viscosity : ............. Would it be a good idea to run the engine with 20W/50 API aa the bike is a bit old (1989) ?
    Only bike I've had in recent history with separate oil for the gearbox (not counting strokers of course) was my last BMW K100 with its completely separate 'box. Does that mean that all my earlier pre-unit Brits were as up to date as modern BMWs?
    20W/50 will do just fine - if you check out the Lubrication section of the online manual you'll see that's actually the preferred option for sunnier climes.
    You're welcome
    kenny1950's Avatar
    kenny1950 is offline Senior Member
    Oct 2006
    Spalding Lincolnshire England
    Cool Re: oils.........
    Give me you email i will send the section from the manual. But remember the manual is quiet old and there are better oils out there now. I use fully sync 10/40 for what it holds it dont cost the earth
    Ken
    Australia
    Re: oils.........
    Hi Ken , thanks for the tip , all under "control" now ...)
    Cheers Jaap.
