Hy guys, I have taken more pics of the oil cooler with the mounting brackets. The bracket that's clamped to the down tube is made of 16 SWG aluminium sheet, you will have to measure the down tube as I think the RDO2 front down tube might be a different size to the RDO8, mine is a RDO8. The horizontal angle bracket which has the cooler mounted is made of 10 SWG aluminium. You will have to cut the return oil pipe that goes up to the underneath side of the oil tank, this will be down to the oil cooler you use. First mount the oil cooler & then decide carefully on the plumbing.
Cheers Richard.
