Hello there, first time posting etc...
I'd like to say there is a pun intended but having spent the whole day trying to do it I'm not so sure!
I've just bought a '95 Domie that "needs a little work" One area was the brakes - it came with Goodrich hoses that had been fitted but not bled. Rear one went OK but I just can't seem to get fluid to move through the front hose and even get close to trying to rid it of bubbles of air. I even went to the point of taking the front caliper off and raising it above the master cylinder on the basis that air must go upwards but to no avail. I'm now thinking that the master cylinder seals must be sufficiently dry or knackered to not be able to force fluid through the system. It currently looks like something out of Emergency Ward 10 with the caliper strapped up high with tubes coming off in all directions and the lever strapped closed with a tie wrap against the handle bar! I noticed tonight when I went for a late night patient visit that a little brake fluid was leaking down the handle bar cover thingies, so I assume I need a master cylinder repair kit - right? Could a very slight weep stop it from being able to purge air from the system?
Thanks for your indulgence
Simon
