Results 1 to 10 of 12
Thread: slow to turn over
    bazzyj Guest
    slow to turn over
    Hi
    Has anyone had a instance where the engine is struggling to turn over on starter, symptons battery low, but this is new battery, seems to only do this when cold?? starter mtr seems ok
    Baz
    sbikerbud is offline Senior Member
    Apr 2007
    birmingham UK
    Re: slow to turn over
    my FMX never sounds very happy to turn over. I was worried it may be the battery so i took it off the bike, charged it overnight, no difference.
    I've watched a few youtube videos where people have started their FMXs and they spin over a lot quicker.
    (if you will excuse the absurdity of trying to put sounds into text) they go
    shuka shuka shuka brum
    where as mine goes
    ssshhhuukkka ssshhhuukkka sssshhhhuuuukkka brum
    and it makes me jealous. lol
    Rubberchicken's Avatar
    Amsterdam
    Mine does that too when it's cold out. As far as I know it's just normal, batteries don't like cold.
    I'm a bit slower than usual as well getting out of bed when it's cold, brrrr. You should hear the GS heaving over in the morning when it's freezing and it's spent the night outside.
    Michel
    '89 NX650 -- R.I.P. -- Gone
    Mervinh's Avatar
    Mervinh is online now Stone Crazy
    Nov 2006
    The dark side of Dartmoor
    Try going through the wiring and making sure the earth to the frame/engine etc is good, the connections to the motor /solenoid are clean, may help. had the same with my mini car years ago very slow to turn over even with a new battery, cleaned up the earth to the body and engine made big difference,
    merv
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Mine get to the compression stroke and stops, keep the button pressed and it get over it a fires. Think somethings wrong with the cam/decomp but can't be arsed to check it out.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Jochen is offline Member
    Nov 2006
    Oud-Beijerland, Netherlands
    I have the same troubles.
    Cannot start electrically, must use the kickstarter
    Mine is a '89, tried jumperstarting, but no go. Took the starter apart but looks brand new. Also checked the (thick) wires, seem all to be allright.
    It is all a mistery to me?!?! Am thiking that the decompression vale is not working allright?!?
    Kicking starting seems normal.
    Greetings.
    mergoofmx's Avatar
    mergoofmx is offline Member
    Mar 2007
    Lancs
    Its because the motor is soooo choked by the exhaust system. change the cans and get rid of the cats(full system) and it will spin over a lot quicker !
    this is what i found anyway when i put a full arrow system on it.
    mat
    shuriken's Avatar
    shuriken is offline Senior Member
    May 2007
    Southsea. UK
    Also check the starter bushes, I bought new battery because of the same symptoms and it turned out to be worn bushes.
    mergoofmx's Avatar
    Mar 2007
    Lancs
    Quote Originally Posted by shuriken View Post
    On a FMX or a dommy? must be a dommy, the guy is onabout a FMX.
    cheers
    mat
    shuriken's Avatar
    May 2007
    Southsea. UK
    Don't FMX's have starter motors? Same engine and starter so symptoms could be the same. Odd on a newer bike but not out of the question.
    yes mine is/was a Dommie.
  1. site seems slow
    By Chad in forum Problems with the forum?
    Last Post: 01-12-07, 09:18 PM
  2. My turn, Was it you
    By Sharribee in forum Chatter
    Last Post: 12-05-07, 12:38 AM
  3. It's a bit slow
    By rlkat in forum Transalp
    Last Post: 16-07-06, 10:17 AM
