Honda Trail Bike Forums
Go Back   Honda Trail Bike Forums > Honda Trail Bikes > Dominator / FMX
Reply
  #1 (permalink)
Old 21-04-08, 04:05 PM
shuriken's Avatar
Senior Member
cylinder head bolts....
Two questions:
1:
Ok, so i bought a 2ft breaker bar yesterday and got 4 of the 6 bolts loose. And with very little effort too. Worth the £19.99 from Halfords. However one has rounded and the other is starting to.
Do I drill out the not head and then once pressure and barrel is off just take off remaining bits or is this sounding to easy?
2:
How and what with, do I take the camchain tensioner holding screw out of the side of the head?
  #2 (permalink)
Old 21-04-08, 06:27 PM
catteeclan's Avatar
Senior Member
Re: cylinder head bolts....
For the head bolts get a single hex socket. (six sided instead of 12).
http://www.oemmotorparts.com/oem5.as...NX650T-E__0400
For the cam tensioner,
Take out bolt 11 in the pic. Then find something to fit in the hole on the top of No 5. Think I used an allen key. You use the allen key as a lever to release the tension.
__________________
08 TDM900,
96 Dominator,
84 XL600lm,
82 XL500r.
  #3 (permalink)
Old 21-04-08, 06:38 PM
shuriken's Avatar
Senior Member
Cool, it's 12 sided I'm using.
As with the bolt, thas what I cant take out!! What do I use to get a purchase on the head as it's an inverted slot?!
  #4 (permalink)
Old 21-04-08, 07:03 PM
catteeclan's Avatar
Senior Member
The tensioner shaft with the slot on the end doesn't have to come out the get the chain/head off. Once the tension is off, or once the cam chain and sprocket are out of the way, you can get hold of the slot with a pair of pliers and pull it out.
Must have bolt 11 out though.
__________________
08 TDM900,
96 Dominator,
84 XL600lm,
82 XL500r.
  #5 (permalink)
Old 21-04-08, 07:20 PM
shuriken's Avatar
Senior Member
That lightens things up.
  #6 (permalink)
Old 22-04-08, 04:30 PM
shuriken's Avatar
Senior Member
One 2ft breaker bar and a deep reach six sided 12mm socket and all is well. Infact it made things almost easy!
Reply
Tags
bolts, cylinder
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
CHAPTER 6 - CYLINDER HEAD & VALVES Confucious Dominator / FMX 16 30-10-09 07:31 PM
WANTED xr250r cylinder head xrmick For Sale / Wanted 0 13-03-08 12:52 PM
xr 250 cylinder head please xrmick XR 0 12-03-08 08:22 AM
cylinder head! itsgoodtotorque Dominator / FMX 7 24-03-07 09:58 AM
