Hi.
I have a Domi 650 89 mod. that i have built to a motard.
I have a problem with my bike.
What i did:
I changed the carburettor to a XR600R carb. to see if the problem went away. The bike started fine and run nice for 5 min then it died out and would not start, it backfires into the carburettor.
So i took it off again and took the original carburettor on again to see if it would run, since i had a problem with this also before i changed tto the XR600R carb. My problem with this carb is that the bike starts very easy and runs beatiful without any throttle. I can take just barely on the throttle so that the bike will go up to about 2000 rpm and thats all. If i try with more throttle hard or small is just the same, It backfires into the carb and will stall at once. The bike will start at once again without any throttle and runs nice again, but if i give throttle then it does the same again backfires hard and dies.
Maby someone can help me out??
