Results 1 to 9 of 9
Thread: smokey on start up but not when running
    kevin nx650 is offline Junior Member
    Jun 2007
    norfolk
    Hi All
    Any suggestions,
    I have a 1991 Dominator which does not smoke whilst running or seem to be burning a lot of oil but once it has been left over night it smokes for under a minute after start up, no odd noises or anything changed.
    Simon WS is offline Member
    Mar 2008
    Kent
    Re: smokey on start up but not when running
    Is you crankcase ventilation system standard Kevin? If it is partially blocked on start up things will get rather smokey. I'm not too sure why a partial blockage would clear after running, but it's the first thing that came into my head (and therefore probably not the answer!)
    Simon
    steved1969's Avatar
    steved1969 is offline Member
    May 2008
    Pontefract, W Yorks
    By 'On Startup' do you mean with the choke one ?
    Assuming it's dark smoke (and we aren't talking plumes of the stuff) that clears up after about 30 secs then it's probably just the engine running rich when you start it. Could be worth changing the plugs as a weak spark could be the cause if it isn't limited to when the choke is on.
    sbikerbud is offline Senior Member
    Apr 2007
    birmingham UK
    if the smoke is light grey/white then its oil smoke.
    Black would indicate over fueling
    sure its not just steam from the zorst?
    If it is just whilst starting i always thought that meant valve stem oil seals.
    Oil seeps past over night, smokey when started (oil sitting on top of valves), gradually clears up (washed clean by incoming fuel/air mix), not noticable when running (due to the small amounts involved).
    Jun 2007
    norfolk
    Hi Guys
    Thanks for the replys, the smoke is light grey and I had wondered about the valve stem seals but thought others may know more, I will check the breather system and plug this weekend as it is an easier job first, if anyone has more info please offer it, thanks again all.
    Regards Kevin
    joch's Avatar
    joch is offline Member
    Jun 2007
    London
    a good way to tell if the valve stem seals are faulty is if it smokes when engine braking. it might take a few seconds for the smoke to show.
    steved1969's Avatar
    May 2008
    Pontefract, W Yorks
    Sorry officer, I'm just trying to see if the engine smokes under engine braking
    BIGROG's Avatar
    BIGROG is offline I need a hug!
    Apr 2008
    On the move yet again... bak dan south!!!
    Stick a tractor zorst on the bike... you can monitor it as you drive, might sound good too
    IM ON THE SAFEHOUSE LIST
    Big white LWB Renault Master Van, mobile home for me,Tess and the bikes
    joch's Avatar
    Jun 2007
    London
    or adjust your mirror...
  1. Running in
    By Tony in forum Mechanical Advice
    Last Post: 04-03-08, 03:10 PM
  2. AT Not running right
    By bazza in forum Africa Twin
    Last Post: 28-02-08, 11:13 PM
  3. Running in Xl 700
    By daveXL700 in forum Transalp
    Last Post: 07-02-08, 11:10 AM
  4. running in
    By kev in forum Transalp
    Last Post: 20-11-05, 04:13 PM
  5. Running hot
    By Ashley in forum Africa Twin
    Last Post: 26-09-05, 07:02 AM
