Results 1 to 3 of 3
Thread: Fuel Overflow on FMX ?
    mattx is offline Junior Member
    London
    I filled up last night and rode home - all well and good - this morning there was a puddle of fuel on my garage floor from what looks like a fuel over flow pipe [ behind the rear brake pedal ]
    There are also other pipes there - can someone explain what these are please ? And do I have a more serious problem - [ bike is still under warrenty - only done 1000 miles ]
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Re: Fuel Overflow on FMX ?
    Get it back to dealer pronto i reckon unless the overflow is from the tank and it was a bit too full, fuel does expand with heat which is why you should never fill your tank right to the top
    Merv
    sbikerbud is offline Senior Member
    Apr 2007
    birmingham UK
    as said above. If you fill it right up then park it the fuel does tend to expand. With it being on the side stand as well it does overflow a bit.
    Fuel out of the underground tanks is about 12 celcius/centigrade and in this hot weather it expands quite a bit
    Last Post: 14-03-09, 09:27 AM
  2. fuel how much how far?
    By Chad in forum Varadero
    Last Post: 10-05-07, 09:41 PM
  3. FUEL TAP
    Last Post: 19-04-06, 10:05 PM
  4. Fuel leak from overflow
    By snaphappyninja in forum Africa Twin
    Last Post: 10-09-05, 12:53 PM
  5. Fuel from overflow question?
    By ghostridergary in forum Africa Twin
    Last Post: 15-10-04, 02:24 PM
