Results 1 to 2 of 2
Thread: Starting RPM?
    stelladragon's Avatar
    stelladragon is offline Junior Member
    Oct 2008
    Preston
    Starting RPM?
    Maybe be I'm being a tad over cautious but I'm a little worried, with the top end failure probs on the Dommie that my 'cold start rpm' is too high. For best results I start on full choke, and immediately back it off to half and it idles at 2500rpm. After 2 mins knock the choke off, down to 1500rpm and ride away. I suppose the question I ask is ..... is 2500 rpm straight away on a cold engine a little high? I change my oil every 1.5 - 2k miles.
    Russ.
    Rubberchicken's Avatar
    Amsterdam
    Re: Starting RPM?
    2500 idle is quite high.
    What I usually do is start on full choke, back it off immediately to less than half to get the revs under 2000, and ride off right after that. A few streets into the ride I can knock the choke off all the way, then I'll still keep it under 4000ish rpm for a couple of minutes until the engine oil's properly warmed up. (Having an oil temp gauge helps here, I basically wait for it to read 60+ deg C before really opening it up.)
    It can all be a bit season specific though, in the height of summer it'll start on half-choke or even no choke at all if it's been sitting in the sun, this time of year it needs the choke a bit more and longer, and if it's freezing it gets really cranky and won't idle properly for quite some time until it's warmed up a bit.
    Michel
    '89 NX650 -- R.I.P. -- Gone
  1. Just starting off...
    By Ian1970 in forum I'd like to introduce myself....................
    Last Post: 07-10-08, 11:25 PM
  2. I had a problem starting my @650
    By Ashley M in forum Africa Twin
    Last Post: 22-05-08, 07:08 PM
  3. XR 400 Hot Starting
    By DaveS in forum XR
    Last Post: 12-06-07, 10:52 PM
  4. Not Starting
    Last Post: 02-11-06, 08:58 AM
  5. Starting
    By Fatjohn in forum Transalp
    Last Post: 20-12-05, 11:58 AM
