Hi all, just cleaned and lubed the chain after a rear shock/swing arm change. Chain is in good condition, as are the sprockets, I know you should measure the slack mid-way between the sprockets but is that on a paddock stand or on the ground?, I have found different amounts of "slack" when checking using these 2 methods. I suppose I am asking should the bike be "loaded" when measuring or just sat on the side stand?. I noticed the ride today was fine but when I checked the chain it seemed quite tight. Thanks in advance, just want to hear what you guys do with respect to this adjustment.![]()
