Results 1 to 5 of 5
Thread: SLR 650 Speedo Cable
    46robbie46's Avatar
    46robbie46 is offline Member
    Sep 2008
    Romford, Essex
    Hi everyone,
    Today i was riding along and went straight across a roundabout pretty fast. Immediatly after the roundabout is the crest of a hill. After going over the crest i loked down and noticed that my speedo wasnt working. it was working immediately before the roundabout.
    When i got home i had a look at it, and there didnt seem to be any damage. It turned out that it wasnt connected to the clocks at the top properly. I.E. It was loose on the thread.
    Anyway, i tightened it up again, tested it up and down the road and it still doesnt work!
    Anyone have any ideas as to what i need to do to fix it?
    Thanks in advance,
    Rob
    starfazer's Avatar
    starfazer is offline Senior Member
    Sep 2008
    Edinburgh
    Re: SLR 650 Speedo Cable
    hi there, a thing for you try, loosen the top nut and give it a shake to make sure that the little square section of cable at the end is engaged into the socket then tighten it up. have done this on other bikes and not got the cable in properly before tightening and have jammed the cable. couple of snapped cables means i always check that sort of thing now. if that doesnt work, undo the cable at the clocks and roll the bike along to see if the cable is rotating. i suppose its all process of elimination at the moment.
    Mark
    46robbie46's Avatar
    Sep 2008
    Romford, Essex
    Aah, thanks for that, i'll give it a go in the morning. Hopefully its just a snapped cable that i can easily replace, rather than the speedo drive or anything more serious like that.
    46robbie46's Avatar
    Sep 2008
    Romford, Essex
    Quick Update,
    Today i took the speedo cable right off the bike, and it turned out that it was snapped it the middle
    Then, i checked that the speedo drive is definatly working, which it is!
    I've ordered a new cable from Bransons Motorcycles in Yeovil, and they say it should be here Thursday afternoon! At £15.39, its not too bad in my opinion!
    Thanks for all the help!!
    Cheers,
    Rob
    46robbie46's Avatar
    Sep 2008
    Romford, Essex
    All fitted up and working! Nice easy job after work lol!
  1. Speedo Cable
    By evilhomer in forum Africa Twin
    Last Post: 14-02-09, 06:37 AM
  2. Replaceing Speedo cable
    By Grendel in forum Transalp
    Last Post: 15-05-08, 04:57 PM
  3. Broken Speedo Cable??
    By Oly in forum Mechanical Advice
    Last Post: 28-03-08, 12:48 PM
  4. Speedo- It's not the cable!
    By louis_holtz in forum Africa Twin
    Last Post: 12-06-07, 09:27 PM
  5. speedo cable
    By jabba in forum Africa Twin
    Last Post: 19-12-05, 09:11 PM
