Page 7 of 9 FirstFirst ... 5 6 7 8 9 LastLast
Results 61 to 70 of 87
Thread: Loud enough?
  1. #61
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Re: Loud enough?
    Out with the misses today and pleased to say the speedo’s pretty good. At 30 mine was reading 31, at 40, 41 and at 70 mine was at 68. So the speedo drive from Domi to FMX are def more different than just the spindle hole.
    Now the sprockets. Def a bit to tall but at 80 mph the revs sit bang on 5000rpm, still pulled but not much good for over-takes. 90 in 4th was easy. Looks like a 14 on the front is on the cards, more for the “chugging”. Anything below 3500 in 5th gear is horrible. 30mph has to be 3rd gear. I noticed this chugging getting worse on the other domi when I changed the standard rear wheel for the fmx. The sprockets then were 16/42.
    FMX forks. Loads firmer, loads less drive when on the brakes which improved as we were out. Was thinking of fitting different pads but won’t bother now. Only bad thing here is I noticed the rubber brake pipe touching the wheel when on the brakes which has worn a good bit of rubber away. Tie wrap saves the day. New pipe on the way as we type. Well pleased with the forks though, just got to get use to them.
    Still got to finish off a few things like the left hand front fairing sticker, any ideas anyone?
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Re: Loud enough?
    Fitted the fmx rear caliper today, only coz it's gold.
    If you zoom in a bit you'll see where the exhaust burned the edge of the side fairing. Should have checked that.
    Done the red line on the rear wheel.
    Still waiting for the 14 tooth sprocket and front brake line.
    That's it I'm going for a ride.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
  4. #63
    El Vencejo is offline Senior Member
    Dec 2009
    Re: Loud enough?
    Very tidy job
    but I hate top boxes with a vengeance
  5. #64
    switch's Avatar
    Feb 2009
    Romania
    Re: Loud enough?
    Awesome, man! But DO re-paint the white sections, will ya? At least carbon-sticker them
  6. #65
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Re: Loud enough?
    Quote Originally Posted by El Vencejo View Post
    Very tidy job
    Don't like the look of them myself but it's to usefull not to have fitted. I'll take it off for the next pic.
    Yes switch still got the stickers to sort but they're not bothering me as much as the blue smoke from the exhaust for a while after start up. Think I pushed it a little to hard on run in.
    Got the brake line sorted but still waiting for the front sprocket. I feel another email to Wemoto on the cards.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
  7. #66
    switch's Avatar
    Feb 2009
    Romania
    Re: Loud enough?
    Quote Originally Posted by catteeclan View Post
    Blue smoke is extremely bad
  8. #67
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Re: Loud enough?
    Here ya go.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
  9. #68
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Re: Loud enough?
    Quote Originally Posted by switch View Post
    Just a bit of oil, I can live with it till I find time to get the glaze buster in the barrel again.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
  10. #69
    switch's Avatar
    Feb 2009
    Romania
    Re: Loud enough?
    Here ya go.
    Do paint the passenger pegs, too, please. By the way, you wouldn't happen to have a full set of footrests around, would you?
  11. #70
    Dec 2009
    Re: Loud enough?
    Top boxes are just an ugly way of upsetting a bike's handling...
    BAD aerodynamics in crosswinds.
    Put any weight in and the centre of gravity of the bike is lifted way high and far back.
    Hate the things.
  1. Loud bang
    By transalper in forum Transalp
    Last Post: 22-04-08, 02:15 PM
  2. Loud engine noise
    By riils in forum Mechanical Advice
    Last Post: 11-06-07, 09:19 PM
  3. loud horn
    Last Post: 25-09-06, 01:34 PM
  4. Loud clothing
    By Whealie in forum Chatter
    Last Post: 23-04-06, 09:30 PM
  5. Loud Engine Noise
    By mickskelly in forum Africa Twin
    Last Post: 31-10-04, 11:15 AM
