Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
Thread: Dominator gear lever slipping on shaft...
  1. #21
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Re: Dominator gear lever slipping on shaft...
    gotta agree with switch, drilles a fs1e kickstart shaft once it snapped in a very short time , not critical on a bike you could put in gear and grab the back wheel to start it
    but without ya gearchange shaft you are looking at big bucks repair and breakdown service to get ya home, unless you have a freind with a bit of rope
    Merv
    switch's Avatar
    Feb 2009
    Romania
    Quote Originally Posted by Mervinh View Post
    Merv
    One could use a spanner to stick the bike in 2nd (for city) or 3rd. You'll burn a bit of clutch but it will get you home. However a broken shaft could lead to oil loss and possibly internal gearbox damage.
  4. #23
    beanfeast is offline Senior Member
    Sep 2007
    Sheffield
    Hi
    I've got an SLR650 and need a replacement gear lever but am struggling to find one online. I assume the Dominator/NX are similar but I'm thrown by what was mentioned a page or 2 earlier - to use a C90 gear lever!?
    Have I just got this wrong, but looking on Ebay this lever is completely different and has 2 pedals on it etc??
  5. #24
    AlanH's Avatar
    Bristol, UK
    Quote Originally Posted by beanfeast View Post
    Hi
    Phone or email David Silver Spares.
  6. #25
    Sep 2007
    Sheffield
    I've emailed them. Would still love to know about the C90 business though!
  7. #26
    Mervinh's Avatar
    Nov 2006
    are you any good with a welder
    YAMBITS
  8. #27
    paulc's Avatar
    paulc is offline Senior Member
    Nov 2009
    Carshalton,London, United Kingdom
    Take some of the butting surface off the gear lever to make it clamp tighter ,it just might work .
    Without seeing the problem and the damage done it's a bit hard to advise you
  9. #28
    paulc's Avatar
    Nov 2009
    Just thought of this .............
    Put the gear lever in the possition you want ,get an angle grinder and grind a decent size grove in both the shaft and the clamp,get a peice of good quality steel (silver steel) that fits and weld onto 'one side only' of the clamp part of the gear lever ,if you weld it on both it wont clamp anymore.
    Would that work?
  10. #29
    jj5
    jj5 is offline Member
    Mar 2010
    Netherlands
    My gear lever has a bit of slack on it. So im looking to replace it. What gear levers go on the dominator?
    Just the NX/XR pedals or are the more options cos i cant find any. Only one overpriced 2nd hand pedal but i want to fix it properly and not end up with the same problem again so i rather get a new one.
  1. Gear lever
    By joe 90 in forum XR
    Last Post: 05-01-09, 10:47 AM
  2. TA Gear Lever
    By jrob0311 in forum Transalp
    Last Post: 23-11-08, 05:33 PM
  3. Slipping out of gear
    By Monsieur in forum Varadero
    Last Post: 28-07-08, 05:17 PM
  4. XR250R Gear Selector Shaft
    By garythehat in forum XR
    Last Post: 23-06-08, 11:43 PM
  5. Gear Lever - new one ?
    By Keef in forum Dominator / FMX
    Last Post: 05-07-07, 07:18 PM
