Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 48 of 48
Thread: Noisy engine ... with Video!
  1. #41
    blackrat's Avatar
    blackrat is offline Junior Member
    Feb 2008
    cluj, romania
    Re: Noisy engine ... with Video!
    i'll only start working on it in the winter cause now i'm using it every day and if i let it warm up in the morning untill the sound dissapears i don't think i'm risking anything.
    i've come to the conclusion that the problem comes from the cam chain which is too loose and the tensioner can't do it's job when cold because there is too much slack. i'm 99% sure that if i cange the tensioner and chain there will be no knocking.
    sometimes i think of leaving it like it is but at some point i'll have to sell it and i don't think anyone would buy a bike with a rattling engine
    blackrat's Avatar
    Feb 2008
    cluj, romania
    one question: do i have to take the head off when i change the chain? beside the head cover and the right engine cover along with the clutch basket
  4. #43
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Quote Originally Posted by blackrat View Post
    You don't have to take the head off but you will if you want to change the forward chain guide. You may be able to get a good look at it to see what condition it's in with a torch.
    Good hunting and take pics.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
  5. #44
    tractot4play is offline Member
    Jan 2009
    belfast
    hi blackrat,when you get your new camchain compare it to the old one and let us know the measurements.best of luck tractor.
  6. #45
    blackrat's Avatar
    Feb 2008
    cluj, romania
    Quote Originally Posted by tractot4play View Post
    I just changed the cam chain last week and by holding it against the old one it was probably half a centimetre shorter (which means 1 cm shorter if you open it up). I haven't started the bike yet because i'm still waiting for the right cover gasket and carburetor insulator (which is awfully expensive btw). I also chenged the chain tensionner spring and i am very curious whether it will rattle any more.
  7. #46
    switch's Avatar
    Feb 2009
    Romania
    Out oc curiosity, is the cam chain identical between NX650 and NX500?
  8. #47
    blackrat's Avatar
    Feb 2008
    cluj, romania
    it's the same it seems
  9. #48
    Warthog's Avatar
    Mar 2007
    Difference between cold and warm can be due to metal expanding and fill any tolerances or it could be the oil....
    Do you have a particularly thick oil in there at the moment, perhaps used during the colder months?
    That might be an over-simplistic suggestion, but....
  1. New Video you might like.
    Last Post: 23-11-08, 05:10 PM
  2. noisy chutch on my o3 650r
    By sambsi in forum XR
    Last Post: 24-05-08, 11:33 PM
  3. noisy Vara... what... I said NOISY VARA
    By Austin in forum Varadero
    Last Post: 18-04-08, 07:49 PM
  4. Noisy Clutch!
    By shack in forum Africa Twin
    Last Post: 01-07-07, 04:19 PM
