I'm now on my 3rd set of silencers and 2nd rear shock in 32,000 miles so I thought I'd try and prolong them by adding a rear hugger. It's taken a while to find one that will fit but I'm quite pleased with the overall result. It's from a Kawasaki ZX-6R J1 and with minimal hacking and drilling it seems to work a real treat. It should keep most of the wet weather off the silencers in a bid to keep them from looking like a rusty sieve in just a couple of years. I'm not sure I'd take a pillion or go off road with it on as it will probably catch on the silencers but as I do neither of those any way it's not going to be a problem.
The lhs is all bolted on nicely to the original chain guard brackets but I haven't got round to doing the rhs properly so it's held on with the bikers no. 1 friend the good old zip tie. The rear brake hose bracket should suffice - I've just got to work out the best way to fix the hose and the hugger to it and then it'll be finished. It's been on for a couple of hundred miles so far without any problems.
Hopefully you can see it clearly in these pictures.
