Results 1 to 10 of 12
Thread: exhaust pipes holders for SLR 650
    cyganmarek's Avatar
    cyganmarek is offline Junior Member
    May 2009
    Chigwell , Essex
    Question exhaust pipes holders for SLR 650
    Hi Everyone!
    I've got problem to find part (because i dont know name of part) for HONDA SLR 650.
    I mean , exhaust pipes coming out from cylinder are hold by two "rings" (my one badlly rusted), screwed up by two chrome bolts (two bolts for one "ring").
    I'm sure you can help me, this same parts i have seen with many singles, probablly DOMINATOR has this same.
    Thank you for any advice.
    AlanH's Avatar
    Bristol, UK
    Re: exhaust pipes holders for SLR 650
    I think what you mean are the 'collars'. I don't know about the SLR but, more often than not nowadays, they come with the front pipes and it's not possible to take them off or replace them individually.
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Aha i wasted a lot of money on my SLR buying secondhand pipes . the dommie has 2 piece rings that you can fit without even removing the exhaust
    i did this on the Vigor very easy will look up part number for ya
    here you go you need 4 of no 1 in this picture, the part number is there, just looked at David Silvers website part number is now 18231MN1670, £9.71 each +vat + postage or lings £44.75 for the 4
    cyganmarek's Avatar
    May 2009
    Chigwell , Essex
    Quote Originally Posted by Mervinh View Post
    Well done Mate !!!
    I'm very thankfull, but if you don't mind, one more thing.
    Will i must to replace gaskets to?
    Thank you once again.
    (i had problem with it few days )
    Mervinh's Avatar
    Nov 2006
    no not unless you remove the exhausts or they are already leaking , it is not neccesary to remove them to fit the new rings as they are in 2 pieces
    merv
    AlanH's Avatar
    Bristol, UK
    Quote Originally Posted by cyganmarek View Post
    Yes, replace the gaskets.
    cyganmarek's Avatar
    May 2009
    Chigwell , Essex
    merv
    Ok!
    But to remove old rings i will have to unscrew the exhausts ?
    cyganmarek's Avatar
    May 2009
    Chigwell , Essex
    Are you sure?
    Mervinh's Avatar
    Nov 2006
    you will not need to remove the exhausts, undo the nuts holding the ring on take old ring away from engine, fit the new 2 piece rings then cut the old ones in half too remove them from the exhaust, much quicker, i just used bolt croppers to remove em when i did mine
    Merv
    cyganmarek's Avatar
    May 2009
    Chigwell , Essex
    Merv
    Good idea!
    Your presence on this forum is highly recommended and usefull for others forum users (especially HONDA SLR 650 users ).
    Thank You.
    (Have you seen my previous post , about engine ticking. Any ideas if yes so)
  1. Wanted: Transalp 600 Front exhaust pipes.
    By petterdiesel in forum For Sale / Wanted
    Last Post: 27-10-08, 07:39 PM
  2. stainless front exhaust pipes?
    By MCsanandreas in forum Transalp
    Last Post: 09-08-08, 11:25 AM
  3. Exhaust end pipes help!!
    By squaretyres in forum Transalp
    Last Post: 18-05-08, 09:06 PM
  4. Warning Light Bulb Holders
    Last Post: 06-08-07, 11:51 AM
  5. exhaust down pipes
    By in forum Transalp
    Last Post: 01-01-70, 01:37 AM
